JustSelectedEntities 64 bit
64 bit Inventor hangs at the line below which runs OK in 32 bit. Is there something missing?
If TypeOf JustSelectedEntities.Item(1) Is DrawingView Then
scottmoyse
any help on this one please? we really could do with it asap. our programmer is about to leave for a 3 month sejourn (lucky ba****d) and this will seriously hold us up on the 64 bit transition.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
It is hard to say without seeing the error or exactly what is happening.  Are you sure you have the filter set up right to select drawingviews?  But even then it shouldn't hang.....
I use this in one of my addins with no problems
          Dim oView As DrawingView
            If TypeOf JustSelectedEntities(1) Is DrawingView Then
                ' Set a reference to the selected View
                oView = JustSelectedEntities(1)
Thanks for the help it pointed me in the right direction.
The dim for oView was global within the module and does not work in 64bit, making it function specific cured the problem.
