Late Set Workaround (Unable to provided typed object when setting object proper)
MechMachineMan
Advisor Advisor
MechMachineMan
I'm hoping someone can provide me with some assistance.
What I'm trying to do is create a generic function that changes the object style after being called by a calling function, but works for various objects
This works fine in vba, but when I try to do it in the rule environment, it wants to force me to use a strongly type variable.
ie the code below does not work if oPL is not strongly typed. However, if you Dim oPL As PartsList, the code works just fine.
How do I get around this, so that I can use a generic object within a function, or is there someway to "late bind" the oPL object to a strong type USING the STRING of the type.
'Below code fails in vb.net/rule environment, but works fine in VBA.
Sub Main()
Dim oSheet As Sheet
oSheet = ThisApplication.ActiveSheet
oNewPLStyle = some strongly type PartsListStyle object
'Set oSheet = ThisApplication.ActiveSheet
'Set oNewPLStyle = some strongly type PartsListStyle object
Call ChangeStyle(oSheet.PartsLists, oNewPLStyle)
End Sub
Sub ChangeStyle(objColl As Object, oNewStyle As Object)
For Each obj In objColl
If Not obj.Style.Equals(oNewStyle) Then
MsgBox("here")
obj.Style = oNewStyle
Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
rossano_praderi
Did you tried to use "variant"?
A Variant can hold absolutely everything. An Object is a narrower type than Variant and can only hold objects.
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
