IV5 VBA Disconnected Client Crash - Attn: Brian Ekins
Message 1 of 1
Hi Brian and everyone,
Neil Munroe suggested that I report a problem that I encountered when
changing the Properties of an .idw. I can grab and set the properties just
fine, but when I try to end the UI, I recieve a "Client Disconnected"
message and IV just dies. One workaround is to issue a .Save command first,
but that is not mentioned in the API reference.
A file with the code attached to it is located in CF under the same subject
line. It contains a Stop command just before the code that will cause the
crash. Please let me know if you can verify the crash and/or suggest any
methods other than to save the file before ending. Thanks in advance.
Cheers!
Alan Rennick
Replies (0)
