Previewing thumbnail
I am trying to find which control to place on a form to enable a thumbnail
preview of any inventor parts simalar to the file open box provides, any
help would be appreciated.
Wayne
Hi Wayne
This is from a post of Patrick in the support ng
Microsoft has a document about the preview picture and all the properties in any
document, you will find a VB example and a free dll to show the thumbnail and
properties.
http://support.microsoft.com/support/kb/articles/Q224/3/51.asp
Kent Keller
http://kwik-mcad.scriptmania.com/
"Wayne" wrote in message
news:EB6E59F28D2309F54D5292E17A0B7540@in.WebX.maYIadrTaRb...
> Wayne
I tried this and it is nice. But now I would like to show the thumbnail in MS-Access. The regular Access-picture object does not accept the thumbnail, but only filenames. Do You happen to know, which object I could use in MS-Access?
Marco
I have absolutely no experience in MS-Access, but I would guess it is the same as
Excell. In Excell I have added a image control to a sheet, and then do something
like this.
Private oFilePropReader As DSOleFile.PropertyReader
Private oDocProp As DSOleFile.DocumentProperties
Private Sub Worksheet_Activate()
Set oFilePropReader = New DSOleFile.PropertyReader
Set oDocProp = oFilePropReader.GetDocumentProperties("D:\Inventor\Feature
Suppression Test Part.ipt")
Me.Image1.Picture = oDocProp.Thumbnail
End Sub
Kent Keller
http://kwikmcad.topcities.com/
"Marco" wrote in message news:f09603b.1@WebX.maYIadrTaRb...
I tried cutting a pasting but I got an error about user defined type not
defined. To make this work what references do you need? Thanks this should
be interesting.
"Kent Keller" wrote in message
news:71CD06E17C36870329C0C88520F3E8B5@in.WebX.maYIadrTaRb...
> Marco
same as
something
> like this.
> End Sub
> Kent Keller
in
thumbnail, but only
Did you download the dll from here?
In the references window you need to have DS: OLE Document Properties 1.4 Object
Library checked
Kent Keller
"Kathy Johnson" wrote in message
news:C6BD8568BF2109FBD465A0232076AAD7@in.WebX.maYIadrTaRb...
> be interesting.
No I had read the original quite I while ago. Thank you for pointing it
out.
Kathy Johsnon
news:3CA840A254F5415CEAE43588D91B8B63@in.WebX.maYIadrTaRb...
Object
> Library checked
> Kent Keller
should
> > be interesting.
