Skinny Image
Skinny Image
Skinny Image
anyone have a idea why when I save a image using
saveimage on the thumbnail gotten by DSOleFile.PropertyReader it ends up
skinny?
here is a side by side of  a iam and the
resultant wmf made by using saveimage on it
Your code would probably be more useful than the images. I use a different
method for extracting those images (straight C++) and my output.
Good judgment comes from experience.
Experience comes from bad judgment.
http://www.acadx.com
"Kent Keller" wrote in message
news:3F3F594C5E7DB1595E5D8FFBCE295297@in.WebX.maYIadrTaRb...
anyone have a idea why when I save a image using saveimage on the thumbnail
gotten by DSOleFile.PropertyReader it ends up skinny?
here is a side by side of a iam and the resultant wmf made by using
saveimage on it
Pressed 'send' a little too quickly. I meant to say that my output is fine.
Hi Frank
This is the basics of the code I am using
Private oFilePropReader As DSOleFile.PropertyReader
Private oDocProp As DSOleFile.DocumentProperties
Private Sub Form_Load()
Dim sFile As String
sFile = "D:\Inventor\Projects\ATV Lift\ATV Lift.iam"
Set oFilePropReader = New DSOleFile.PropertyReader
Set oDocProp = oFilePropReader.GetDocumentProperties(sFile)
Picture1.Picture = oDocProp.Thumbnail
SavePicture Picture1, Left(sFile, Len(sFile) - 3) & "wmf"
End Sub
Kent Keller
http://kwik-mcad.scriptmania.com/
"Frank Oquendo" wrote in message
news:DF819134D6B047C23BAB19EF1A5DC4AF@in.WebX.maYIadrTaRb...
Kent,
Have you tried saving as bmp instead of wmf ?
Here is the help about SavePicture from VB6, look at the
remarks.
SavePicture Statement
Saves a graphic from the Picture or Image property of an object
or control (if one is associated with it) to a file.
Syntax
SavePicture picture, stringexpression
The SavePicture statement syntax has these parts:
Part Description
picture Picture or Image control from which the
graphics file is to be created.
stringexpression Filename of the graphics file to
save.
Remarks
If a graphic was loaded from a file to the Picture property of
an object, either at
size=2>design time
or at
href="javascript:alink_4.Click()">run time
and it’s a bitmap, icon, metafile, or enhanced metafile, it's saved using the
same format as the original file. If it is a GIF or JPEG file, it is saved as a
bitmap file.
Graphics in an Image property are always saved as bitmap (.bmp)
files regardless of their original format.
"Kent Keller" <
href="mailto:kwik.mcad@verizon.net">
size=2>kwik.mcad@verizon.net
> wrote in message
size=2>news:326D639F5C8443E791C49ADA1D4C0CCE@in.WebX.maYIadrTaRb
size=2>...
| Hi Frank
| This is the basics
| Private oDocProp As
    Dim sFile As String
|     sFile =
|     Set
|     Set
|     SavePicture
| End Sub
| Kent Keller
href="http://kwik-mcad.scriptmania.com/">
size=2>http://kwik-mcad.scriptmania.com/
"Frank Oquendo" <
size=2>franko@acadx.com
> wrote in message
size=2>news:DF819134D6B047C23BAB19EF1A5DC4AF@in.WebX.maYIadrTaRb
size=2>...
output is fine.
experience.
size=2>http://www.acadx.com
Hi Patrick
Yes that is the first thing I tried, but when I tried to open it in Irfanview it told me
that the format wasn't bmp and it was either WMF or ......some other format, I can't
remember right now. I will give it a shot as a bmp again tonight though and verify.
Kent
"Patrick de Stobbeleir" wrote in message
news:E9FC5550FFA303DC1E999DE7E7940937@in.WebX.maYIadrTaRb...
> Kent,
> Here is the help about SavePicture from VB6, look at the remarks.
