IV2009 VBA - Does user have to work about leaks w/ Transient Geometry?
IV2009 VBA
Does a user have to worry about memory leaks with Transient Geometry or does the TransientGeometry Object clean up any object that are unused? For example, will this cause a memory leak?
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oV0 As Vector
Set oV0 = oTG.CreateVector(0, 0, 0)
Set oV0 = oTG.CreateVector(0, 0, 1) ' does this call cause the first vector to be leaked?
This should be ok. Reusing the variable should cause the initial reference
to be released.
Brian Ekins
Autodesk Inventor API
I figured the TransientGeometry object was managing it. Thanks for verifying Brian!
