Code for automatic check-in @ close, ANYONE???
Hello, I have searched & searched only to find no answers. Maybe I'll call AUTODESK out on this one! I know that I'm not alone in this issue because I've seen posts dated back to 2004 that have all of the same concerns. Maybe they've found answers and never posted them, I don't know. But either way, I have yet to find an answer.
Here's my situation. Our company is new to using Inventor. The first job we did we ran Single-User project files. We are now running Shared-User projects. We can not run Vault yet because we do not have the IT resources or time to get it all setup. So please don't reply with "just use Vault." I am looking for some sort of code or routine that would automatically check-in a part when the user closes that part file. We have multiple people working on jobs and grabbing other peoples parts to make their own and going in & out of other peoples parts to check things. It is a pain to have to Steal Checkout all the time. With that being said, we aren't so worried about "locking" a model so that no one else can ever touch it. Honestly, we are looking for something similar to AutoCAD's read-only feature. Where a file is only Read-Only if a person is currently in it.
Does anyone have any sort of code, ideas, thoughts, insight, or anything that would help me? Maybe the answer is "NO, there's nothing out there like that." Which would just be a slap to the face to Autodesk (if you ask me). Maybe I'm just to comfortable with AutoCAD methods and need to adapt to Inventor. Either way, can someone put a little insight into this post as to how to handle this situation.
Any & all advice is greatly appreciated. Thanks in advance for any help & criticism that this may bring upon me.
-JRodriguez
here are my solution, works with VBA in Inventor and as VB6-AddIn (when you add the AddIn specific code).
It uses the Inventor events to do the things.
I've made 2 part's one with the auto check-in on document close and as a maybe usefull bonus the auto check-out on start editing a document.
Comment out the msgbox()-code, this is for testing only.
If you use my code in your company please report your experiences!
Have fun,
Guido
###### Here are the class-module "clsAddInAutoCheckIn" for automatic check-in, works with shared mode and semi-isolated mode Inventor-projects:
Option Explicit
Private WithEvents eA As ApplicationEvents
Private Sub Class_Initialize()
Set eA = ThisApplication.ApplicationEvents
MsgBox "AddInAutoCheckIn initialized"
End Sub
Private Sub Class_Terminate()
Set eA = Nothing
MsgBox "AddInAutoCheckIn terminated"
End Sub
Private Sub eA_OnCloseDocument(ByVal DocumentObject As Document, ByVal FullFileName As String, ByVal BeforeOrAfter As EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum)
Static bState As Boolean
' HandlingCode = kEventNotHandled
If bState Then
Exit Sub
If BeforeOrAfter kBefore Then
Exit Sub
bState = True
On Error Resume Next
If DocumentObject.ReservedForWriteByMe Then
Call DocumentObject.RevertReservedForWriteByMe
On Error GoTo 0
bState = False
End Sub
###### Here are the class-module "clsAddInAutoCheckOut" for automatic check-out on edit, works only with shared mode Inventor-projects, NOT with semi-isolated mode:
Option Explicit
MsgBox "AddInAutoCheckOut initialized"
End Sub
Set eA = Nothing
MsgBox "AddInAutoCheckOut terminated"
End Sub
Private Sub eA_OnNewEditObject(ByVal EditObject As Object, ByVal BeforeOrAfter As EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As HandlingCodeEnum)
If bState Then
Exit Sub
If BeforeOrAfter kAfter Then
Exit Sub
If EditObject.Type kDocumentObject Then
Exit Sub
bState = True
If Not EditObject.ReservedForWrite Then
EditObject.ReservedForWriteByMe = True
On Error GoTo 0
bState = False
End Sub
###### Here are the module "AddInEvents" to start the event-handlers:
Option Explicit
Private oEvents1 As clsAddInAutoCheckOut
Private oEvents2 As clsAddInAutoCheckIn
Sub AutoCheckOutStart()
Set oEvents1 = New clsAddInAutoCheckOut
End Sub
Sub AutoCheckOutStop()
Set oEvents1 = Nothing
End Sub
Sub AutoCheckInStart()
Set oEvents2 = New clsAddInAutoCheckIn
End Sub
Sub AutoCheckInStop()
Set oEvents2 = Nothing
End Sub
Have you tested this on Inventor native DWG files?
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:5922225@discussion.autodesk.com...
Have fun,
Guido
Option Explicit
End Sub
Set eA = Nothing
End Sub
If bState Then
Exit Sub
Exit Sub
bState = True
On Error GoTo 0
bState = False
End Sub
semi-isolated mode:
Option Explicit
End Sub
Set eA = Nothing
End Sub
If bState Then
Exit Sub
Exit Sub
Exit Sub
bState = True
On Error GoTo 0
bState = False
End Sub
Option Explicit
End Sub
End Sub
End Sub
End Sub
NO!
Good hint, I'll try this shortly.
Do you tested this? What's your experiences?
I need more reports from users, so I can improve my solution.
I have made an extension, that listends to the project-changed event, checks what project-type the current project are and enableds or disableds the auto-checkin/checkout. This is in alpha-testing now...
CU,
Guido
We are using your automatic check in code, it solves lot of troubles.
Does it still work well for you?
Thank you for the contribution
Thomas
Also check out CBliss' Unreserve program. I think it still works with current releases. It is very handy when working with and managing Shared projects.
http://www.cbliss.com/inventor/iCode/index.htm
Pete
