Iterate through weldment suboccurence and get fulldocument name
guillaume.canor
guillaume.canor
Hello everyone,
I'm having a problem with an API I'm wirting. I'm iterating through an assembly to get iProperties and fulldocumentname of each occurence. In fact, the routine goes well exept when I'm adding a weldment subassembly (normal subassembly do no wrong). Here is the base code i'm using to do that :
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer)
' Iterate through all of the occurrence in this collection.  This
' represents the occurrences at the top level of an assembly.
  Dim oOcc As ComponentOccurrence
   For Each oOcc In Occurrences
    Dim oOccPath As String = oOcc.ReferencedDocumentDescriptor.FullDocumentName
 'Check to see if this occurrence represents a subassembly
 'and recursively call this function to traverse through it.
    If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
         Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
     End If
   Next
End Sub
With this code, I get the weldment path but not the one of the parts in it. The program gives me an error because oOcc.ReferencedDocumentDescriptor.FullDocumentName is nothing which I don't understand.
I hope someone can help me. I am at a loss there.
JelteDeJong
In a weldment assembly, the welds are also occurrences. (That is a bit counter-intuitive) Because weld are virtual parts there is no referenced document. (This also implies that you will run in trouble if you have virtual parts in a normal assembly.) Try this:
    For Each oOcc As ComponentOccurrence In Occurrences
        If (oOcc.ReferencedDocumentDescriptor Is Nothing) Then
            MsgBox(oOcc.Name & " has none refrence document")
            Continue For
        End If
        If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        End If
    Next
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
guillaume.canor
Thank for the quick  and well explained answer. That resolved my problem 🙂
