Dimensions having gaps in dimension line
Tiffany_Hayden_
Tiffany_Hayden_
Hi -
I'm creating dimensions through the API and I noticed when I do, sometimes, there is a gap in the dimension. I've tried to run a sheet update after placing the dim but it doesn't help. If I move the dim manually after the automation has run it completes the line and everything looks good. Anyone ran into this yet?
Tiffany Hayden
bradeneuropeArthur
Could you share the code, so we can have a look in this?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Tiffany_Hayden_
Here's the area of the code that's creating the dim. @bradeneuropeArthur
                If Not oIntent1 Is Nothing And Not oIntent2 Is Nothing Then
                    Set oTextPt2D = ThisApplication.TransientGeometry.CreatePoint2d(oCLIn.StartPoint.X, oCLIn.StartPoint.Y + 3)
                    Set oDim = IsCompDimOnSheet(oDrawView, oIntent1, oIntent2)
                    If oDim Is Nothing Then
                        If intCount > 1 Then
                            strPartialDimText = "(" & CStr(intCount) & ")" & " INT-" & strModelFirst(0) & " @ " & ReturnPropVal(oOccIntFirst.Definition.Document, "LENGTH") & " EACH"
                        Else
                            strPartialDimText = "*INT-" & strModel(0)
                        Set oDim = oSheet.DrawingDimensions.GeneralDimensions.AddLinear(oTextPt2D, oIntent2, oIntent1, kAlignedDimensionType, True)
                        Set oDimText = oDim.Text
                        oDimText.FormattedText = oDimText.FormattedText & vbCrLf & strPartialDimText
                        oDim.CenterText
                    Call oDrawView.SetVisibility(oWPlInProxy, False)
                    Call oDrawView.SetVisibility(oWPlOutProxy, False)
Tiffany Hayden
