Item Number to iProperty 2
marcin_bargiel
marcin_bargiel
Hi there was similar topic, but i have different issue.
I'm also trying to find a way to catch the Item number (structured BOM) and create an iProperty "BOM Number" in every assembly's parts.
Problem is that,  rule doesn't add BOM Number to parts that have the same filename (i have many parts with the same filenames - and i'm not going to change it! they always are in different folder) . It adds only to the first occurance as i understand.
When using this :
For i = 1 To oBOMRow.ComponentDefinitions.Count
iProperties.Value(oBOMRow.ComponentDefinitions(i).Document.DisplayName, "Custom", "BOM Number") = oBOMItemNumber
Next
When using this instead of above code :
oComponentDefinitionPropertySet.Item("BOM Number").Value = oBOMItemNumber
Problem is when i have many parts with the same Partname- it adds BOM Number to the first of it.
Can anyone help me ?
Whole rule here, and also attached with my TEST FILES.
Sub Main()
Dim oAssemblyDocument As AssemblyDocument
oAssemblyDocument = ThisDoc.Document
Dim oAssemblyComponentDefinition As AssemblyComponentDefinition
oAssemblyComponentDefinition = oAssemblyDocument.ComponentDefinition
Dim oBOM As BOM
oBOM = oAssemblyComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews(2) 'Structured view
oBOM.StructuredViewFirstLevelOnly = False
oBOM.StructuredViewDelimiter = "."
Call RecursiveCheckAndSetProps(oBOMView.BOMRows)
End Sub
Sub RecursiveCheckAndSetProps(ByVal oRowsElements As BOMRowsEnumerator)
For Each oBOMRow As BOMRow In oRowsElements
Dim oComponentDefinition As ComponentDefinition
oComponentDefinition = oBOMRow.ComponentDefinitions.Item(1)
Dim oBOMItemNumber As String
oBOMItemNumber = oBOMRow.ItemNumber() 'this is item number in the BOM
'Logger.Info(oBOMItemNumber & " BOM Number") 'just to show what's going on
Dim oComponentDefinitionPropertySet As PropertySet
oComponentDefinitionPropertySet = oComponentDefinition.Document.PropertySets.Item("Inventor User Defined Properties")
'Try
'If already exists Then Set it
On Error Resume Next
'oComponentDefinitionPropertySet.Item("BOM Number").Value = oBOMItemNumber
Logger.Info(oBOMRow.ComponentDefinitions(i).Document.DisplayName & " - " & oBOMItemNumber)
Next
'Catch ex As Exception
'else add it
oComponentDefinitionPropertySet.Add(oBOMItemNumber, "BOM Number")
'End Try
'creates the custom property and inputs the value
If Not oBOMRow.ChildRows Is Nothing Then
Call RecursiveCheckAndSetProps(oBOMRow.ChildRows)
End If
Next
End Sub
Vote for REPLACE VARIES !
REPLACE VARIES
tonythm
Hi @marcin_bargiel
You can refer code below:
I use excel vba.
Sub SetItemBOM()
    Dim oWkbk As Workbook
    Set oWkbk = ThisWorkbook
    Dim oSheet As Worksheet
    Set oSheet = oWkbk.ActiveSheet
    Dim oInv As Inventor.Application
    Set oInv = GetObject(, "Inventor.Application")
    Dim oDoc As Document
    Set oDoc = oInv.ActiveDocument
    ' Set a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oAssy As AssemblyDocument
    Set oAssy = oInv.ActiveDocument
    Dim sParamRange As String
        sParamRange = "A44:A200"
    ' Set a reference to the BOM
    Dim oBOM As BOM
    Set oBOM = oDoc.ComponentDefinition.BOM
    oBOM.StructuredViewFirstLevelOnly = True ' Display First level
    oBOM.StructuredViewMinimumDigits = 3
    Set oBOMView = oBOM.BOMViews.Item("Structured")
    Dim i As Integer
    For i = 1 To oBOMView.BOMRows.Count
        Dim oRow As BOMRow
        Set oRow = oBOMView.BOMRows.Item(i)
        Dim oCompDef As ComponentDefinition
        Set oCompDef = oRow.ComponentDefinitions.Item(1)
        Dim oPartNumProperty As Property
        Set oPartNumProperty = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number")
        Dim oCell As Range
        For Each oCell In oSheet.Range(sParamRange)
            If oCell.Value = oPartNumProperty.Value Then
            oRow.ItemNumber = oCell.Offset(0, 1).Value
            End If
            'If oCell.Value = oPartNumProperty.Value Then
                'If oCell.Offset(0, 2).Value = oRow.ItemQuantity Then
                'oCell.Offset(0, 2).Interior.Color = RGB(0, 176, 240)
                'Else
                'oCell.Offset(0, 2).Interior.Color = RGB(255, 0, 0)
                'End If
            'End If
        Next oCell
    Next
    Range("A40").Select
    MsgBox ("Done!")
    oWkbk.Save
End Sub
marcin_bargiel
thanks, but that's not very helpful to my problem
REPLACE VARIES
marcin_bargiel
can anyone help me on the topic?
REPLACE VARIES
marcin_otręba
try:
Sub Main()
Dim oBOM As BOM
End Sub
oComponentDefinitionPropertySet = oBOMRow.ComponentDefinitions(i).Document.PropertySets.Item(4)
Try
Catch
	oComponentDefinitionPropertySet.Item("BOM Number").Value=oBOMItemNumber
End Try
Next
End If
Next
End Sub
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
j.pavlicek
@marcin_bargiel Hello, I see problem on line (24)
Where the first Component Definition is stored in variable oComponentDefinition.
Following for goes trough all of the definitions, but oComponentDefinition* is still targeting the first definition.
Next
 You need something like
oComponentDefinition = oBOMRow.ComponentDefinitions.Item(i)
inside the for cycle.
Inventor 2022, Windows 10 Pro
Sorry for bad English.
marcin_bargiel
MANY THANK'S !!!
REPLACE VARIES
