i dont know a standard function that does that but i wrote a ilogic rule that does this.
[iLogic]
Dim COLUMNNAME = "First used"
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = doc.ActiveSheet
Dim partsList As PartsList = oSheet.PartsLists.Item(1)
' collect item numbers, sheet numbers and location
Dim firstUseList As Dictionary(Of String, String) = New Dictionary(Of String, String)()
For index = 1 To doc.Sheets.Count
For Each balloon As Balloon In doc.Sheets.Item(index).Balloons
Dim bomRow As DrawingBOMRow = balloon.BalloonValueSets.Item(1).ReferencedRow
Dim itemNr As String = bomRow.BOMRow.ItemNumber
If (firstUseList.ContainsKey(itemNr) = False) Then
Dim baloondata As String = "SHT. " & index
baloondata = baloondata & ": " & Math.Round(balloon.Position.X * 10, 0)
baloondata = baloondata & "," & Math.Round(balloon.Position.Y * 10, 0)
firstUseList.Add(itemNr, baloondata)
Next
Next
' search in partslist for the columns with item numbers and the 'First use' column.
Dim firstUsedColumnNr As Integer = -1
Dim itemNrColumn As Integer = -1
For i = 1 To partsList.PartsListColumns.Count
If (partsList.PartsListColumns.Item(i).Title.Equals(COLUMNNAME)) Then
firstUsedColumnNr = i
If (partsList.PartsListColumns.Item(i).PropertyType = PropertyTypeEnum.kItemPartsListProperty) Then
itemNrColumn = i
Next
' if the 'First use' column does not exists then cerate it
If (firstUsedColumnNr = -1) Then
firstUsedColumnNr = partsList.PartsListColumns.Count + 1
Dim oPropSet As PropertySet = doc.PropertySets.Item("Inventor User Defined Properties")
Dim id As String = oPropSet.InternalName
partsList.PartsListColumns.Add(PropertyTypeEnum.kCustomProperty, id, COLUMNNAME)
' add the collected data to the 'First use' column
For index = 1 To partsList.PartsListRows.Count
Dim partsListRow As PartsListRow = partsList.PartsListRows.Item(index)
Dim itemNrCell As PartsListCell = partsListRow.Item(itemNrColumn)
If (firstUseList.ContainsKey(itemNrCell.Value)) Then
Dim firstUseCell As PartsListCell = partsListRow.Item(firstUsedColumnNr)
firstUseCell.Static = True
firstUseCell.Value = firstUseList(itemNrCell.Value)
Next
copy past this in a rule and excute it when the sheet with the partslist is active. I was not able to get the "position square" of the ballon but i was able to get the coordinates (x,y)
Jelte de Jong
Blog: hjalte.nl - github.com
