Item # Balloon locator
Gang,
Probably a long shot.... In an .idw, is it possible for Inventor to auto populate on my BOM where the first used balloon is. On our drawings we identify within a column on our BOM that specifies what sheet and zone the first callout of a balloon is located. With BOM's sometimes containing over 100 item #'s this proves useful to our assemblers as it saves them the time of flipping through a 20-30 page drawing to find a balloon. This is currently handled with manual inputs from our designers. Adding or removing a sheet from the drawing or additional item #'s introduces opportunity for errors and our current method is very daunting. See attached.
Thank you in advance!
Shawn
JelteDeJong
i dont know a standard function that does that but i wrote a ilogic rule that does this.
[iLogic]
Dim COLUMNNAME = "First used"
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = doc.ActiveSheet
Dim partsList As PartsList = oSheet.PartsLists.Item(1)
' collect item numbers, sheet numbers and location
Dim firstUseList As Dictionary(Of String, String) = New Dictionary(Of String, String)()
For index = 1 To doc.Sheets.Count
    For Each balloon As Balloon In doc.Sheets.Item(index).Balloons
        Dim bomRow As DrawingBOMRow = balloon.BalloonValueSets.Item(1).ReferencedRow
        Dim itemNr As String = bomRow.BOMRow.ItemNumber
        If (firstUseList.ContainsKey(itemNr) = False) Then
            Dim baloondata As String = "SHT. " & index
            baloondata = baloondata & ": " & Math.Round(balloon.Position.X * 10, 0)
            baloondata = baloondata & "," & Math.Round(balloon.Position.Y * 10, 0)
            firstUseList.Add(itemNr, baloondata)
        End If
    Next
Next
' search in partslist for the columns with item numbers and the 'First use' column.
Dim firstUsedColumnNr As Integer = -1
Dim itemNrColumn As Integer = -1
For i = 1 To partsList.PartsListColumns.Count
    If (partsList.PartsListColumns.Item(i).Title.Equals(COLUMNNAME)) Then
        firstUsedColumnNr = i
    End If
    If (partsList.PartsListColumns.Item(i).PropertyType = PropertyTypeEnum.kItemPartsListProperty) Then
        itemNrColumn = i
    End If
Next
' if the 'First use' column does not exists then cerate it
If (firstUsedColumnNr = -1) Then
    firstUsedColumnNr = partsList.PartsListColumns.Count + 1
	Dim oPropSet As PropertySet = doc.PropertySets.Item("Inventor User Defined Properties")
	Dim id As String = oPropSet.InternalName
    partsList.PartsListColumns.Add(PropertyTypeEnum.kCustomProperty, id, COLUMNNAME)
End If
' add the collected data to the 'First use' column
For index = 1 To partsList.PartsListRows.Count
    Dim partsListRow As PartsListRow = partsList.PartsListRows.Item(index)
    Dim itemNrCell As PartsListCell = partsListRow.Item(itemNrColumn)
    If (firstUseList.ContainsKey(itemNrCell.Value)) Then
        Dim firstUseCell As PartsListCell = partsListRow.Item(firstUsedColumnNr)
        firstUseCell.Static = True
        firstUseCell.Value = firstUseList(itemNrCell.Value)
    End If
Next
copy past this in a rule and excute it when the sheet with the partslist is active. I was not able to get the "position square" of the ballon but i was able to get the coordinates (x,y)
Jelte de Jong
Blog: hjalte.nl - github.com
Thank you very much for your reply. i am going to try this script this weekend from home and am very excited as this would save an enormous amount of manual editing. Again thank you very much and I will let you know my outcome.
