Edit PDF in iLogic
Edit PDF in iLogic
pavol_krasnansky
Message 1 of 8
Edit PDF in iLogic
pavol_krasnansky
Hello
I need to add text (stamp) into exist PDF file in iLogic rule on computer without Adobe Reader Professional (I cannot create object "AcroExch.App") Does way exist?
Thank you
Replies (7)
Message 2 of 8
Mark.Lancaster
@pavol_krasnansky
Use the Inventor customization forum for this https://forums.autodesk.com/t5/inventor-customization/bd-p/120
I will have the moderator relocate your posting there to best suit your needs.
Mark Lancaster
Message 3 of 8
machiel.veldkamp
You should have adobe Pro installed.
This is a merge pdf function... ArrayFilePaths should contain paths (C:/.../file.pdf) to which PDF's should be merged.
Sub MergePdfs(arrayFilePaths)
Logger.Info("MergePDFs")
Try
AdobeApp = CreateObject("Acroexch.app")
primaryDoc = CreateObject("AcroExch.PDDoc")
Catch
MessageBox.Show("Adobe Pro required. Canceling PDF Merge", "MergePdfs")
Logger.Info("Adobe Pro required. Canceling PDF Merge")
Exit Sub
End Try
' Copy primary doc and open the copy.
' arrayFilePaths(0)' copy this file and open the copy?
oOriginalName = arrayFilePaths(0)
oCopyName = Left(arrayFilePaths(0), Len(arrayFilePaths(0)) -4) & "-PACKET.pdf"
System.IO.File.Copy(oOriginalName, oCopyName)
arrayFilePaths(0) = oCopyName
OK = primaryDoc.Open(arrayFilePaths(0))
' Logger.Info("PRIMARY DOC OPENED & PDDOC SET: " & OK)
For arrayIndex = 1 To UBound(arrayFilePaths)
numPages = primaryDoc.GetNumPages() -1
sourceDoc = CreateObject("AcroExch.PDDoc")
OK = sourceDoc.Open(arrayFilePaths(arrayIndex))
' Logger.Info("SOURCE DOC OPENED & PDDOC SET: " & OK)
numberOfPagesToInsert = sourceDoc.GetNumPages
OK = primaryDoc.InsertPages(numPages, sourceDoc, 0, numberOfPagesToInsert, False)
' Logger.Info("PAGES INSERTED SUCCESSFULLY: " & OK)
OK = primaryDoc.Save(PDSaveFull, arrayFilePaths(0))
' Logger.Info("PRIMARYDOC SAVED PROPERLY: " & OK)
sourceDoc = Nothing
Next arrayIndex
primaryDoc = Nothing
AdobeApp.Exit
AdobeApp = Nothing
End Sub
Hope it helps.
___________________________
Message 4 of 8
pavol_krasnansky
Thank you for answers
I want to find some solutions with using for example free DLL libraries or something similar. Adobe Reader Professional is not free software.
Message 5 of 8
machiel.veldkamp
Ah. Well I don't have that example. I just know that Adobe Pro can do it with their extensive API.
Good luck, I hope that you find what you're looking for.
Could you reply if you eventually do find a free solution?
Message 6 of 8
pavol_krasnansky
Yes of course, I will publish solution, if I find somethínk.
Message 7 of 8
pavol_krasnansky
Hello
I found solutions with using libraries PDFsharp:
www.pdfsharp.net
AddReference "PdfSharp.dll"
AddReference "System.Drawing.dll"
' Opening existing PDF
Dim oDoc_PDF As PdfSharp.Pdf.PdfDocument = PdfSharp.Pdf.IO.PdfReader.Open("C:\TEMP\Test.pdf", PdfSharp.Pdf.IO.PdfDocumentOpenMode.Modify)
' Set font encoding to unicode
Dim oFont_Options As PdfSharp.Drawing.XPdfFontOptions = New PdfSharp.Drawing.XPdfFontOptions(PdfSharp.Pdf.PdfFontEncoding.Unicode, PdfSharp.Pdf.PdfFontEmbedding.Always)
For i = 0 To oDoc_PDF.PageCount - 1
' Get an object of PDF sheet
Dim oSheet_PDF As PdfSharp.Pdf.PdfPage = oDoc_PDF.Pages(i)
' Get a size of PDF Sheet
Dim Width_Of_PDF_Sheet As Integer = oSheet_PDF.Width
Dim Height_Of_PDF_Sheet As Integer = oSheet_PDF.Height
' Get an XGraphics object for drawing
Dim oGfx As PdfSharp.Drawing.XGraphics = PdfSharp.Drawing.XGraphics.FromPdfPage(oSheet_PDF)
' Get an object of font for inserted text
Dim oFont As PdfSharp.Drawing.XFont = New PdfSharp.Drawing.XFont("Arial", 20, PdfSharp.Drawing.XFontStyle.Regular, oFont_Options)
' Inserting text into sheet of PDF
oGfx.DrawString("Hello Autodesk Inventor!", oFont, PdfSharp.Drawing.XBrushes.Black, Width_Of_PDF_Sheet / 2, Height_Of_PDF_Sheet / 2, PdfSharp.Drawing.XStringFormats.Center)
Next
' Save and close PDF
oDoc_PDF.Save("C:\TEMP\Test.pdf")
' oDoc_PDF.Save("C:\TEMP\Test2.pdf")
oDoc_PDF.Close()
oDoc_PDF = Nothing
Message 8 of 8
pavol_krasnansky
Hello
www.pdfsharp.net
Next
oDoc_PDF.Close()
oDoc_PDF = Nothing
