Visibilty of model funtions in a part with a split.
D0UGLAS
D0UGLAS
Hi I have a model with many ilogic functions which can be masked and unmasked.
I think there is a fault if I activate a split feature the other active features lose their luminosity and are hard to find and edit, my solution is to roll back to before the split and the features reappear, the problem then has another undesired result as I quite often close the model without rolling it forward again. Is there a solution for this?
chandra.shekar.g
Autodesk Support
Autodesk Support
@D0UGLAS,
Please provide non confidential files and iLogic code to reproduce the behavior.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
D0UGLAS
Hi Chandra,
If you send me a private message with an email I can send you a link to the data set..
D0UGLAS
I tried to send you the link but I get this message
You have reached the limit for number of private messages that you can send for now. Please try again later.
This is strange as I hardly ever send messages.
