Issues with Parts not updating when changed by ilogic in the Assembly (Inventor 2020)
rluttrell
Observer Observer
rluttrell
Observer
Observer
I am attempting to make a part that changes the dimensions it uses to determine its sized based on options in the assembly.  Basically it is a curved part that i want to be able to have its length set by either its Angle, long point to long point dimension, or arc length.
This is currently my Assembly iLogic.
Parameter("BOT_D_PLT", "METHOD") = Wall_Length_Method
If Wall_Length_Method = "ARC LENGTH" Then
	Parameter("BOT_D_PLT", "Wall_Arc_Length") = Wall_Arc_Length
End If
If Wall_Length_Method = "P2P" Then
	Parameter("BOT_D_PLT", "Wall_P2P") = Wall_Length_Point_To_Poiint
End If
If Wall_Length_Method = "ANGLE" Then
	Parameter("BOT_D_PLT", "Wall_Angle") = Wall_Angle
End If
Parameter("BOT_D_PLT", "Radius") = Outside_Radius
Parameter("BOT_D_PLT", "Width") = Wall_Thickness
Parameter("BOT_D_PLT", "Thickness") = 1.0 in
And this is currently my Part iLogic
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCD As ComponentDefinition = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch = oCD.Sketches.Item(1)
Dim oDim As DimensionConstraint
	For Each oDim In oSketch.DimensionConstraints
		If oDim.Parameter.Name = "P2P" Then oDim.Driven = True
		If oDim.Parameter.Name = "ANGLE" Then oDim.Driven = True
		If oDim.Parameter.Name = "ARC_LENGTH" Then oDim.Driven = True
	Next
If Not METHOD = "" Then
	If METHOD = "ARC LENGTH" Then
		If oDim.Parameter.Name = "ARC_LENGTH" Then oDim.Driven = False
	Next
	ARC_LENGTH = Wall_Arc_Length
End If
If METHOD = "P2P" Then
			If oDim.Parameter.Name = "P2P" Then oDim.Driven = False
	Next
	P2P = Wall_P2P
End If
If METHOD = "ANGLE" Then
		If oDim.Parameter.Name = "ANGLE" Then oDim.Driven = False
	Next
	End If
	ANGLE = Wall_Angle
End If
InventorVb.DocumentUpdate()
iLogicVb.UpdateWhenDone = True
Both of these seem to work.  But when i change the options in the assembly, the dimensions update their DRIVEN status, but do not update to new values.  If i step into the part and run its rule everything updates as it should.
Any advice on how i can make this behave?
A.Acheson
Hi @rluttrell
Can you share an image of the browser where the parameter is acting on?
Can you share an image of what is updating and what isn't?
Regards
Alan
TKey_Luttrell
here is a part with the sketch
current assembly parameters
now lets change to the Arc Length method
note the Wall_Arc_Length parameter is 60 in.
but the arc length dimension on the sketch is 62.832 in.
despite the PART parameters
showing 60 as the Wall_Arc_Length
now if i run the rule manually in the part (which we know has already been run because the driven dimensions have changed.)
NOW everything is correct
now lets step back into the assembly and change the arc length, just to see if it updates without a change to the driven dimensions
changed it to 120 in, and it updated immediately.
changed the method to Angle.
As you see the Angle is now the undriven dimension, but it is not 60deg like it should be.
My current theory as to what is happening here.  is that when the rule is called the parameter ANGLE is a Referenced Parameter, and thus cannot be changed, and despite the fact that it IS NOT a referenced parameter when it gets to the point where i tell it to change it still thinks it is, so it doesnt change it.  But when i rerun the rule it is a Model Parameter and can be changed.
A.Acheson
My assumption is that the parameter isn't updating as the rule is running but after it has ran. This could be due to ilogic API controlling the part parameter at the assembly level. The part parameters at the part level are controlled by the inventor API.
See parameter update method here
  • Parameter.UpdateAfterChange = True
    True will cause the model (document) to Update after a parameter value is changed by the Parameter function. This only takes effect when you change parameters using the Parameter function. For example:
See updating the document method here
RuleParametersOutput
If your rule has changed any parameter values, this function applies new rule values to the Inventor model. If this function is not used, the values are not applied until the rule has finished running. Use this function if you must perform an Update using DocumentUpdate. Also use this function if you are using the iLogicVb.RunRule function, so that the other rule gets the new values of the parameters.
Syntax
RuleParametersOutput()
DocumentUpdate
Performs an immediate update in the current document (the document that the rule is in) and updates the display. Use this function if you require that the geometry be rebuilt (for example, you are calculating mass using iProperties.Mass). If the rule fires other rules (by changing parameters), enable the Fire dependent rules immediately option for the rule in the Edit Rule dialog box. This option ensures that the other rules have finished running when you perform the update.
Syntax
Regards
Alan
TKey_Luttrell
After more testing i am pretty sure it is the fact that the rules cannot SEE the change from Driven Dimension to Normal Dimension.  ie if i am in Arc_Length mode, and i change the arc length, it will update the arc_length and regenerate the part.  But if i change modes, it will not regenerate the part.  I have tried seperating things out so i am only doing one task at a time, to no avail.  I tried splitting things out into subroutines called by its own rule, with updates called for between each call, to no avail.  And i am out of time to fight with this thing for now, so i am going to have to just accept that things have to be manually regenerated.  But if anyone can come up with a method, please, let me know.
