Vb.Net: CheckedListBox - Get The Value From A Certain Line
isocam
isocam
Can anybody help?
I have a CheckedListBox in a Vb.Net application that I am using with Inventor.
I need to get the value from a certain line in the CheckedListBox and, for testing purposes, display it in a message box.
For example, say I have a CheckListBox containing 5-lines of text thus....
BLACK
WHITE
GREEN
YELLOW
RED
How do I get the value of line 3, for example (in this case it would be GREEN)?
I am using the code:
Msgbox(CheckedListBox1.GetItemText(3))
But it is giving me a number and not the text "GREEN"
Many thanks in advance!
Darren
WCrihfield
Have you already tried just CheckedListBox1.Items.Item(3)?  I do not recall if that collection maintains the original order or not though.
Wesley Crihfield
(Not an Autodesk Employee)
FINET_Laurent
Hi @isocam,
Not too sure about the .getItemText method. I would use this instead :
Public Class Form1
    Private Sub Button1_Click() Handles Button1.Click
        MsgBox(CheckedListBox1.Items(0).ToString())
    End Sub
End Class
Does this suits your needs?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
FINET_Laurent
@isocamn,
Also note the starting index of the collection is 0.
Kind regards,
FINETL.
