- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm essentially performing a copy design on on an assembly by going through all the occurences, and copying them using the SaveAs command in ilogic. It is working well except for when i have the same part in 2 different assemblies. It will copy the first, and all the parts in it. This also does the parts in the second assembly, before it does a save as of that. The end result is it copies everything fine, However, when i come to open the original second assembly, it has the new copied parts in it.
I have not told inventor to save this file. I have also tried copying the assemblies first, and the parts second, but this also doesn;t seem to work.
Does anyone have any ideas how i can get around this problem? I somehow need to refresh the file from vault, but it doesn;t even know it's changed, so i have to delete it, and get it again... but i cant do that with ilogic because it's read only!
Im looping through all my occurences with this sub
SaveAsComponentAndDrawing(oOcc As ComponentOccurrence, TemplateFolder As String) i = i+1 oProgressBar.Message = ("Performing Copy Design on Part " & i & " of " & iStepCount & vbCrLf & oOcc.Name) '...and increase the progress bar scale oProgressBar.UpdateProgress 'full file name with extension CurrentFullFilename = oOcc.ReferencedFileDescriptor.FullFileName 'file name without extension CurrentFilename = TemplateFolder & IO.Path.GetFileNameWithoutExtension(CurrentFullFilename) 'file extension only oExtension = CurrentFullFilename.Substring(CurrentFullFilename.Length - 4) CheckIfDrawingExists(CurrentFilename) oNewFileName = ReturnNewFileName(oOcc) oNewDrawingName = oNewFileName.Substring(0,oNewFileName.Length - 4) & ".dwg" 'True opens visible, False opens invisible ooDoc = ThisApplication.Documents.Open(CurrentFullFilename, True) ' opens ipt file 'set part number ooDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value = IO.Path.GetFileNameWithoutExtension(oNewFileName) ooDoc.SaveAs(oNewFileName, False) ' false means open new file 'ooDoc.Update() ooDoc.Close 'Open the current drawing (In same folder location) Dim DrawingDoc As DrawingDocument = ThisApplication.Documents.Open(CurrentFilename & ".dwg",True) 'Perform 'Save As' on the drawing DrawingDoc.SaveAs(oNewDrawingName, False) ' false means open new file 'Replace reference to assembly model Dim oFD As FileDescriptor oFD = DrawingDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor oFD.ReplaceReference(oNewFileName) DrawingDoc.Update() Try DrawingDoc.Parameters.Item("i").Value = 1 Catch End Try DrawingDoc.Update DrawingDoc.Save DrawingDoc.Close 'ooDoc.Close ComponentArray.Add(oNewName & oExtension) For Each subOcc As ComponentOccurrence In oOcc.SubOccurrences If subOcc.Name.Contains(TemplateCode) SaveAsComponentAndDrawing(subOcc, TemplateFolder) End If Next End Sub
