Is there an easy way to distribute an ILogic Script as an .exe?
ian.berns
ian.berns
Hello All,
My colleagues and I have been working on an ILogic Script in Inventor to automate our workflow. However, when distributing it to colleagues, it has become a long tedious process. Is there an easy way to convert it into a .exe?
Or would our best option be to port the project to VB.NET in Visual Studio and build an installer from there?
Thank you all for your time.
T
T
WCrihfield
To ensure all my other colleagues can access and use the iLogic solutions I author, I have set up a shared network location where all our shared resources are kept, including a folder (specified within iLogic Configuration) where all the external iLogic rules and forms are kept (with sub folders).  All we had to do after setting up this shared location, was to make sure we all had our iLogic Configuration settings set the same (these settings can be exported/imported as .xml file).  This works great for our team, but I don't know if this would work for a team whose members may be regularly remote working (not on same network, accessing over internet).
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
ian.berns
I really appreciate the response. I like that idea a lot, but unfortunately we have a lot of remote workers across the country! I will keep that in mind if I cannot find another solution. Thank you
bradeneuropeArthur
In the past I used a .bat file that copies the files to the correct location with a script.
I put that in the startup folder of windows.
Each time the correct files were copied before inventor started up.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
