is there a way to give inventor an command alias input form ilogic ?
Darkforce_the_ilogic_guy
Advisor Advisor
bradeneuropeArthur
First you need to create that command, with a description an command name. I know how to do that with an addin but with I logic this is different. An addin runs in background, ilogic not.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
WCrihfield
Hi @Darkforce_the_ilogic_guy.  I am not sure I fully understand what you want to do here, but I gave this simple code a try (and various permutations of it) in Inventor 2024, from both an internal iLogic rule, then from an external iLogic rule (ran by right-click on rule, then choosing Run Rule, so that the rule dialog was not showing at the time), and that still did not work.  If I just tap the "S" key on my keyboard, while I have a part document open, and not in any other commands, it acts like clicking on the 2D sketch command button, and asks me to choose a plane to start the sketch on.  So clearly trying to do this from an iLogic rule is not working the same as you may be expecting.
AppActivate(ThisApplication.Caption)
System.Windows.Forms.SendKeys.SendWait("S")
ThisApplication.UserInterfaceManager.DoEvents
Wesley Crihfield
(Not an Autodesk Employee)
