is there a way to find all Browser notes that does not show the partnumber ?
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 8
is there a way to find all Browser notes that does not show the part number ? we are more then 10 uses, that Create our model in a full version og inventor.  But We have one use that only have Access to an Read Only.. He need the browsernotes to Always show the current part number. But for some reason there is always some form time to time some that show the wrong number... I try a lot of ilogic code to try to fix this on save... but for some reason some still seens to happen. Is there a easy way to fix this .. So it 100 % of the time show the part number for our read only user ?
Replies (7)
Message 2 of 8
marcin_otręba
check this ilogic to reset name to be equal to part number:
Dim ass As AssemblyDocument = ThisDoc.Document
For Each occ As ComponentOccurrence In ass.ComponentDefinition.Occurrences
	If Split(occ.Name, ":")(0) <> occ.Definition.Document.propertysets(3)("Part Number").value Then
	occ.Name = ""
	Dim doc As PartDocument = occ.Definition.Document
	doc.DisplayName = doc.propertysets(3)("Part Number").value
	occ.Name = ""
	End If
	End If
Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 8
WCrihfield
Why not just use the built-in Rename Browser Nodes tool for that?
We can put a copy of that tool button out in the 'User Commands' panel of the ribbon if we want to make it more convenient to use.
One of its options is to reset all component occurrence browser nodes to their Part Number.
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 8
marcin_otręba
@WCrihfield you can imagine addin for saving and replacing occurrences in assembly for example wchich should check that names and correct it  do it after replacing part... you cant trust that end user will click that button.
Message 5 of 8
WCrihfield
Good point.  Just mentioning the simplest things first, before potentially the most complex ones.  Since he mentioned that he was already using iLogic tools to help solve this issue, but they were not working so far, I kind of wanted more details before suggesting more iLogic, but did not include the questions I had in mind, due to other distractions.  It would have been nice if the existing example code(s) he was using were posted here, maybe as attached text files, that way we could review them, instead of shooting in the dark.  Maybe the code he has is OK, but just not being ran often enough or when needed.  Or maybe his codes are throwing errors or skipping past errors that need to be dealt with instead of ignored.  Since there had not been any mention about them using 'design copy' or 'save & replace' strategies so far, so I did not want to assume anything quite yet, but just wanted more information to go on.
By the way, I think the block of code you posted could also potentially throw errors in certain situations.  For example, if any of the components were suppressed, then the third line of code would throw an error, because it can not access the definition of a suppressed component.  Also if any of the components represented ModelState members, it likely would not allow editing their document DisplayName property value...at least not until the factory document version was obtained/used, or similar counter measures for dealing with ModelStates.
Since the iLogic Event Triggers dialog only offers a limited set of events, and are not always the most efficient to use, a custom add-in may be the way to go here, as long as everyone on the team who has 'edit' rights had that add-in in place.  We do not really know yet what is going on which is causing the components to not be named as their part numbers, so determining which events to monitor and react to is still needed.
Wesley Crihfield
Message 6 of 8
marcin_otręba
sure, the code should be updated to have some error handling  using simplest on error resume next, try catch  or checking occurrence supression state, but i think he will manage to do it..
Message 7 of 8
built-in Rename Browser Nodes ? well that easy people forget 😁 and the user that need it more then any other  only have a read only version of inventor.  I have try many ways to do this ...I din´t type in my post but I have a exceptions in my code...but my problem is that in at make it reset all the browsernote it will take too long .. if i try to make some form of check well all ways i have try so far seens to miss some of them for no good reason i can find ... I didt find some that help a lillte .. by making our read only user use he BOM function and save hen a few click to dobble check his work.
My code run on save 🙂
'this my current code
'Reset Browsernote that dont show the partnummer
Sub Main()
	Dim doc = ThisApplication.ActiveDocument
	Dim sDocumentSubType As String = doc.SubType
	Try
		'debug("Start ilogic: RenameBrowsernoteAll")
		Logger.Info("Start ilogic: RenameBrowsernoteAll")
		oDoc = ThisDoc.Document
		Dim oPane As BrowserPane
		Dim oTopNode As BrowserNode
			If oDoc.DocumentType = kPartDocumentObject
				oPane = oDoc.BrowserPanes.Item("PmDefault")
			Else 'kAssemblyDocumentObject or
					oPane = oDoc.BrowserPanes.Item("Model")
			End If
				oTopNode = oPane.TopNode
			If oTopNode.BrowserNodeDefinition.Label <> System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) Then
				oDoc.DisplayName = "" 'System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
			End If
	Catch
		debug("RenameBrowsernoteALL ilogic code fail for unknown reason")
	End Try
If sDocumentSubType = "{E60F81E1-49B3-11D0-93C3-7E0706000000}" Or sDocumentSubType = "{28EC8354-9024-440F-A8A2-0E0E55D635B0}" Then ' = "assembly"''
If(doc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = iProperties.Value("Project", "Part Number")) Then
Assembly
Else
	Logger.Info("This is not the Aktive Doc - End Code")
Exit Sub
End If
End If
'debug("End ilogic: RenameBrowsernoteAll")
Logger.Info("End ilogic: RenameBrowsernoteAll")
End Sub
Public Sub debug(txt As String)
        Trace.WriteLine("NTI : " & txt)
End Sub
Sub Assembly()
	Logger.Info("Change Browsernotes Assembly", filename)
	Dim oAsmDoc As AssemblyDocument
	oAsmDoc = ThisApplication.ActiveDocument
	If (ThisDoc.Document.DisplayName = oAsmDoc.DisplayName) Then
	Else
		Logger.Info("Don´t run - End Code", filename)
		Exit Sub
	End If
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
	Try
	Catch
		Try
			If oRefDoc.DisplayName <> oRefDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value Then
				Logger.Info("All need To be true " & (Left(oRefDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value,9) <> "Zero Line").ToString & " " &  (Left(oRefDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value,9) <> "Zero line").ToString & " " & (Left(oRefDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value,15) <> "Control cabinet").ToString, filename)
					If Left(oRefDoc.DisplayName,9) <> "Zero Line" And Left(oRefDoc.DisplayName,9) <> "Zero line" And Left(oRefDoc.DisplayName,15) <> "Control cabinet"   Then
					oRefDoc.DisplayName = ""
					End If
			End If
		Catch
		End Try
	End Try
Next
Dim asm As AssemblyDocument = ThisDoc.Document
ResetOccurrenceNames(asm.ComponentDefinition.Occurrences)
End Sub
Sub ResetOccurrenceNames(occurrences As Object)
	Try
	For Each occ As ComponentOccurrence In occurrences
		Dim dispName = occ.ReferencedDocumentDescriptor.DisplayName
		'start
		Dim oPartDoc As Document
    oPartDoc = occ.Definition.Document
    Dim partNumber As String
    partNumber = iProperties.Value(oPartDoc, "Project", "Part Number")
		'end
		Dim length = Len(partNumber) -4
		If Not occ.Name.StartsWith(Left(dispName,length)) Then
		Logger.Info(occ.Name.StartsWith(Left(dispName,length)), "2")
If(Left(occ.Name, 9)) <> "Zero Line" And (Left(occ.Name, 9)) <> "Zero line" And (Left(occ.Name, 15)) <> "Control cabinet" Then
		occ.Name = ""
	End If
		Logger.Info("Reset browsernote", filename)
		Else
			If Left(occ.Name.ToString, Len(dispName)) = dispName Then
			Else
			Logger.Info(occ.Name.StartsWith(Left(dispName,length)) & " 2" , "2")
			Logger.Info("Browser Note " & occ.Name, filename)
If (Left(occ.Name, 9)) <> "Zero Line" And (Left(occ.Name, 9)) <> "Zero line" And (Left(occ.Name, 15)) <> "Control cabinet" Then
			occ.Name = ""
		End If
		End If
	End If
		'ResetOccurrenceNames(occ.SubOccurrences)
	Next
	Catch
		Logger.Info("somthing fail "   , filename)
	End Try
End Sub
Message 8 of 8
WCrihfield
Hi @Darkforce_the_ilogic_guy.  That is a bit difficult to review and understand, but I definitely saw some error prone areas in it.  Since I already had a couple saved snippets in my iLogic toolbox from helping a couple other people out with similar requests, I decided that it might be easier for me to start from one of those examples, then modify it as needed, than attempt to fix your current example code.  Although the concept of this task seems very simple, it is not actually that simple to make happen automatically, entirely by code in a comprehensive way that would work without any errors or problems.  There are simply some situations which are difficult or impossible to deal with.  It is possible that some documents involved are ReadOnly, such as Content Center or 'Library' stuff, and various others.  When that is the case, their Document.DisplayName can not be changed.  When a component is suppressed, there is not much we can do with it, or the document it references, without throwing errors, because a lot of the data associated with it are unloaded from Inventor's memory, for performance reasons.  Sometimes, if there are multiple instances / occurrences referencing multiple different ModelState versions of the same source file, that means that there are multiple 'Documents' being held in Inventor's memory, which all reference back to the same file on disk, and we will not be able to modify some of those Documents the way we want.  Then there is the simple fact that no two component occurrences in an assembly can have exactly the same name.  So, if 4 occurrences all reference a Document with the same Part Number value, we can not simply name all 4 of those occurrences that Part Number value.  There has to be some sort of naming convention with a 'sequential' aspect to it, to make each of them unique.  Inventor usually handles that stuff automatically for us by putting the colon character (:) then an Integer as an index number after each instance that references the same source file, but that does not happen automatically when doing things by code.
Attached is a text file containing the code for a very long iLogic rule with several separate methods involved.  I chose to employ a strategy of using a Dictionary to bundle components by the Part Number value of the documents they reference.  That way all the ones with the same Part Number value can be renamed in a controlled sequence, with an Integer type Index system.  You can change how that system works if you want to, but this is just an example of how it could be done.  You can give that rule a try if you want, or just review its contents for ideas about how to potentially fix your current code example.  I have not tested it yet myself, because I have no use for it, and do not want to change any of my files in those ways.  I hope this helps some.
Wesley Crihfield
