Editing feature definitions after creation?
J_Pfeifer_
J_Pfeifer_
Good morning friends, I'm running into a situation where the Topological Naming is messing up my flange editor.
The first thing of note there are only 3 variations of this type to be applied and modified from the model. A 2", 3" and 4" option. The 2" and 3" are both tapered while the 4" is not. All I'm attempting to do is change the size and placement of these items dynamically. or basically swap between them using form inputs.
The issue is, the OD of the 4" situation is larger than the bottom of my model (bottom radius cannot be changed). Adding a face to the combine cut that's used to cut this and the gusset features. It then breaks my shell feature unable to calculate the proper faces for the shell.
Sub main()
	Dim App As Inventor.Application = ThisApplication
	Dim oDoc As PartDocument = App.ActiveDocument
	Dim CompDef As PartComponentDefinition = oDoc.ComponentDefinition
	Dim oTO As TransientObjects = App.TransientObjects
	Dim oParams As Inventor.UserParameters = CompDef.Parameters.UserParameters
	Dim oShell As ShellFeature = CompDef.Features.ShellFeatures.Item("F2 Shell feature")
	Dim oShellDef As ShellDefinition = oShell.Definition
	Dim oCombine As CombineFeature = CompDef.Features.CombineFeatures.Item("F2 combine")
	Dim FaceCol As FaceCollection = oTO.CreateFaceCollection
	For Each iFace As Face In oCombine.Faces
		If iFace.Evaluator.Area < 1 Then
			FaceCol.Add(iFace)
	Next
	oShell.SetEndOfPart(True)
	For Each iFace As Face In FaceCol
		oShellDef.InputFaces.Add(iFace)
	Next
	CompDef.SetEndOfPartToTopOrBottom(False)
End Sub
The above code has been modified multiple times in an attempt to suppress, move end of part, specify different faces, clear the face collection and more. This includes confirming that the face that's claim to be missing, has already been loaded into the collection. Or at least the Evaluator.area is the same.
Attached are two photos. One shows the 2 + 3" layout, while the other shows the 4". I've circled the face messing this up in red, in blue I've pointed out the seam creating the face issue.
Any held would be greatly appreciated!
Curtis_Waguespack
@J_Pfeifer_ , your code looks right to me, other than: should this be greater than < rather then > than ? Maybe not? I might be misinterpreting the intent
			FaceCol.Add(iFace)
J_Pfeifer_
This was an If I threw into the loop due to already logging and checking the values with measure. The face being added is .811 area. The code provided has changed multiple times with different logs and otherwise. This is just the state I happened to copy it for a question.
I cant really tell what's happening at the feature definition. I've logged the count before clearing the input faces. I've tried adding faces to the collection. The log after still claims the same amount of faces in the collection. Then I read that some of the definitions are in read only after the creation of the feature. To which I attempted to suppress the feature to no avail. Then I moved the end of part above disabling the feature still no luck.
I know that the program side does not function the same as the manual inputs, however If i edit the feature. I can select that small circle, click ok, and the feature solves correctly.
All of this to say, anything I seem to do to the .inputfaces does not take effect on the feature.
Curtis_Waguespack
@J_Pfeifer_
It should be read/write according to this
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=ShellFeature_Definition
Also, on second glance, it looks like the InputFaces is just the faces to remove, maybe? See examples for creating a new shell.
Dim oDoc As PartDocument = ThisDoc.Document
Dim oPDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oFaces As FaceCollection = ThisApplication.TransientObjects.CreateFaceCollection
Dim oBody As SurfaceBody
Dim oFace As Inventor.Face
Dim oShellFeats As ShellFeatures
Dim oShelllFeat As ShellFeature
Dim oThickness As Double = .1
oShellFeats = oPDef.Features.ShellFeatures
' just for testing
Try
oShelllFeat = oShellFeats.Item("MyShell")
oShelllFeat.Delete
Catch
End Try
oBody = oPDef.SurfaceBodies.Item(1)
oFace = oBody.Faces.Item(2)
oFaces.Add(oFace)
oShellDef = oShellFeats.CreateShellDefinition(oFaces, oThickness, ShellDirectionEnum.kInsideShellDirection)
oShelllFeat = oShellFeats.Add(oShellDef)
oShelllFeat.Name = "MyShell"
This example specifies no faces
' just for testing
Try
oShelllFeat.Delete
Catch
End Try
'oFace = oBody.Faces.Item(2)
'oFaces.Add(oFace)
