Is "master" model state name localized?
nmunro
Message 1 of 9
nmunro
Can't seem to find an answer to this anywhere. Is the name for the master model state (ModelStateName) changed in localized versions of Inventor?
https://c3mcad.com
Replies (8)
Message 2 of 9
bradeneuropeArthur
What do you exactly mean with "changed in localized versions of Inventor"?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
nmunro
In a non-English language Inventor version, is "Master" translated to the local equivalent.
https://c3mcad.com
Message 4 of 9
Curtis_Waguespack
Hi @nmunro
I think it would be a different name. And in fact in Inventor 2023 they discarded the name "Master" and use "Primary" for the English versions. I think the safest way to access the "built in" model state is probably via item number as in this example.
I hope this helps.
Curtis
	Dim oDoc As AssemblyDocument
	oDoc = ThisApplication.ActiveDocument
	Dim oModelStates As ModelStates
	oModelStates = oDoc.ComponentDefinition.ModelStates
	'get the built in model state
	oBuilt_In_MS = oModelStates.Item(1)
	MsgBox(oBuilt_In_MS.Name,,"iLogic")
Message 5 of 9
nmunro
Thanks Curtis, your solution was one on my list. Still would like to know if anyone can check a localized version.
https://c3mcad.com
Message 6 of 9
Michael.Navara
Use string identifiers are common, but bad practice. Use built-in enums instead. It is not culture (language) specific. Here is sample how to detect master model state
Dim asm As AssemblyDocument = ThisDoc.Document
Dim activeModelState As ModelState = asm.ComponentDefinition.ModelStates.ActiveModelState
Logger.Debug("Active model stsate is {0}", activeModelState.ModelStateType)
If activeModelState.ModelStateType = ModelStateTypeEnum.kMasterModelStateType Then
	Logger.Debug("Master model state")
Message 7 of 9
bradeneuropeArthur
Does this help you further?
	Dim ms As Inventor.ModelState
	For Each ms In oModelStates
	If ms.ModelStateType = Inventor.ModelStateTypeEnum.kMasterModelStateType Then
		MsgBox("Model state Master")
	Else If ms.ModelStateType = Inventor.ModelStateTypeEnum.kCustomModelStateType Then
		MsgBox("Model state Custom")
	Else If ms.ModelStateType = Inventor.ModelStateTypeEnum.kSubstituteModelStateType Then
		MsgBox("Model state Substitute")
	Else If ms.ModelStateType = Inventor.ModelStateTypeEnum.kLastActiveModelStateType Then
		MsgBox("Model state Active")
		Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 9
CattabianiI
No one mentioned the proper class to manage localization, so I add some links:
' Method that returns whether the input primary model state string
' is valid or not. The input primary model state string can be in
' any language that Inventor supports.
ThisApplication.LanguageTools.IsValidPrimaryModelState(PrimaryName As String)
' Read-only property that returns the primary ModelState string in current language.
ThisApplication.LanguageTools.CurrentPrimaryModelStateString
Message 9 of 9
WCrihfield
Just pointing out another set of ModelState related tools that you (and others) may like.
One of these seems to contain a tool that sounds like an exact match for checking your request.
This appears to be a direct way get the 'localized' version of a supplied ModelState name.
Dim oMSName As String = "Master"
Dim oMSNUtils As New Autodesk.iLogic.Runtime.ModelStateNameUtils
Dim sLocalizedName As String = oMSNUtils.GetLocalizedName(oMSName)
MsgBox("The 'Localized' version of " & oMSName & " is:  " & sLocalizedName, vbInformation, "iLogic")
The main tool being used there (ModelStateNameUtils) could be used without the "Autodesk.iLogic.Runtime" part, but I just added that so others would know where it is being sourced from, but the 'Runtime' source is already referenced for us automatically by the iLogic Add-in, when working within the iLogic Rule Editor dialog.  However, I could not find an online help area web page which documents this tool, or I would have provided a link to it here.  This tool appears to be somewhat of a 'behind the scenes' resource which appears to have most of the same functionality as the LanguageTools referred to by @CattabianiI.  It has the following members:
Then there is the ModelStateUtils tool, which is also sourced from the 'Autodesk.iLogic.Runtime' reference, and also does not appear to have an online help webpage.  This is a really helpful and interesting tool, with several 'members', and you do not need to 'instantiate' it (no need to create a variable for it, or use 'New' to create one), which is also really nice.  Some of us may recognize some of these 'members' as having similar sounding normal API counterparts.  Again, this may be a 'behind the scenes' resource type tool.  Probably just for providing a 'shortcut' of sorts.  This tool has the following 'members':
Then there is the ModelStateOperations tool, which is also from the Runtime source, and does not need to be instantiated, but only has two methods.  Not super useful, but nice to know its there.
Then there are also a few ModelState related tools under the FileManager object (ThisApplication.FileManager), which there is actually a online help webpage for.
Wesley Crihfield
(Not an Autodesk Employee)
