Is a flat pattern sheetmetal part open?
DWhiteley
Advisor Advisor
DWhiteley
I'm trying to find out if the current open document is in flat pattern "mode"
It's not working, any ideas what I've got wrong?
If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
'MsgBox("sheet metal")
If OApp.ActiveEditDocument.Type = 50332160 Then
' this is a a flat pattern
End If
End If
Many thanks in advance.
Dave
GeorgK
' Check to see if the flat pattern exists.
    Set oFlatPattern = oPartDoc.ComponentDefinition.FlatPattern
    If oFlatPattern Is Nothing Then
        MsgBox "No flat pattern exists for this part!"
        Exit Sub
    End If
DWhiteley
Thank you for this, but I need to know if the flat pattern is currently active (I think your code shows if a flat pattern exists).
Dave
DWhiteley
Thank you, but this is still not what I want to achieve.
I just need to know whether the flat pattern is active on the screen. Not whether a flat pattern exists or to switch between flat and folded.
Dave
Ktomberlin
If TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then
        MessageBox.Show("Flat Pattern Active", "Title")
    End If
I think this does what you want, or if you want it to check the other way
If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then
        MessageBox.Show("Flat Pattern is NOT Active", "Title")
    End If
