iProperty error "conversion from string "" to type "Double" is not valid
mcloughlin_b
mcloughlin_b
HI Boffins
I am trying to copy the value (string) from an existing custom iProperty  across to a new custom property  but am stumbling over string to double conversion.
It appears that a few of the existing parts have the old property set to type "number" and i am needing to copy it into a new property of type text. I have tried using the CStr function but it seems to have no effect. Code is below
SyntaxEditor Code Snippet
If GetProperty(oCstPropSet, "SYBIZ PART No.").Value <> "" Then
			Dim VIZNO As String = CStr(GetProperty(oCstPropSet, "SYBIZ PART No.").Value)
			GetProperty(oCstPropSet, "SYBIZ PART NO").Value = VIZNO
			oCstPropSet.Item("SYBIZ PART No.").Delete
			Else If GetProperty(oCstPropSet, "SYBIZ PART No.").Value = "" Then
 Any ideas / help appreciated as I'm sure this is really simple but .........
Bryan
bradeneuropeArthur
you don't need the conversion I assume.
			Dim VIZNO As String = (GetProperty(oCstPropSet, "SYBIZ PART No.").Value)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
mcloughlin_b
Nope I do. The code I posted is not working.
Cheers
bradeneuropeArthur
can you post the complete code?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
Are you programming VBA Vb.net or I-logic?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
mcloughlin_b
Hi Braden
Code is iLogic. Please see below
Sub Main
'debugger line, to see when rule runs
Trace.WriteLine("Tidy up iProperties: external rule", "iLogic")
Dim oCurrentDoc As Inventor.Document
Dim oDoc As Inventor.Document
Dim oPartDoc As PartDocument
Dim oRefDoc As DocumentsEnumerator
oCurrentDoc = ThisApplication.ActiveDocument
If oCurrentDoc.DocumentType = kAssemblyDocumentObject Then
	For Each oDoc In oCurrentDoc.AllReferencedDocuments
	ErHa = "Start"
	Try
		If oDoc.DocumentType = kPartDocumentObject Then
			oPartDoc = oDoc
		'define custom property set
		Dim oCstPropSet As PropertySet
		oCstPropSet = oPartDoc.PropertySets.Item("Inventor User Defined Properties")
		ErHa = "Sybiz Part No."
	    ErHa = "SUPPLY NO"
		If GetProperty(oCstPropSet, "SUPPLY NO").Value <> "" Then
			Dim sSUPPLYNO As String = GetProperty(oCstPropSet, "SUPPLY NO").Value
			GetProperty(oCstPropSet, "SUPPLYNO").Value = sSUPPLYNO
			oCstPropSet.Item("SUPPLY NO").Delete
			Else If GetProperty(oCstPropSet, "SUPPLY NO").Value = "" Then
		ErHa = "SUPPLY TYPE."
		If GetProperty(oCstPropSet, "SUPPLY TYPE").Value <> "" Then
			Dim sSUPPLYNO As String = GetProperty(oCstPropSet, "SUPPLY TYPE").Value
			GetProperty(oCstPropSet, "SUPPLYTYPE").Value = sSUPPLYNO
			oCstPropSet.Item("SUPPLY TYPE").Delete
			Else If GetProperty(oCstPropSet, "SUPPLY TYPE").Value = "" Then
		ErHa = "Update the file"
		'iLogicVb.UpdateWhenDone = True
	Catch ex As Exception
		MsgBox("Part: " & oDoc.DisplayName & vbLf & "Code-Part: " & ErHa & vbLf & "Error: " & ex.Message)
	End Try
	Next
End Sub
Private ErHa As String = vbNullString
Function GetProperty(oCstPropset As PropertySet, iProName As String) As Inventor.Property
    ErHa = "GetProperty: " & iProName
    Dim iPro As Inventor.Property
    Try
        'Attempt to get the iProperty from the document
        iPro = oCstPropset.Item(iProName)
    Catch
        'Assume error means not found, so create it
        iPro = oCstPropset.Add("", iProName)
    End Try
    Return iPro
End Function
bradeneuropeArthur
Sub Main
	ErHa = "Start"
	Try
			oPartDoc = oDoc
		If GetProperty(oCstPropSet, "SYBIZ PART NO").Value <> "" Then
			Dim VIZNO As String = CStr(GetProperty(oCstPropSet, "SYBIZ PART NO").Value)
			oCstPropSet.Item("SYBIZ PART NO").Delete
			Else If GetProperty(oCstPropSet, "SYBIZ PART NO").Value = "" Then
	    ErHa = "SUPPLY NO"
	End Try
	Next
End Sub
    Try
    Catch
        iPro = oCstPropset.Add(" ", iProName)
    End Try
    Return iPro
End Function
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
