iProperties Sent to DXFs
cadman777
Advisor Advisor
cadman777
Hey Guys,
I'm trying to figure out how to make a  part's Custom iProperty values transfer into the exported DXF flatpattern files. The iProperties themselves transfer, but not all the values transfer, since some of them are empty when I open them in AutoCAD and look at the file's 'Drawing Properties'. Is there a setting in the INI file that controls that? Or is there some code I can use? Where can I find the info on this?
Any light shined on this is appreciated...
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Ralf_Krieg
Hello
AFAIK there is no export of properties possible. Wonder that you export some of the custom props. Sure they are not in your dxf template?
DXF is a text file. I think it would be possible to export it, open afterwards and write the properties. Each block for a property should look like example below.
$CUSTOMPROPERTYTAG
1
TestPropertyName
9
$CUSTOMPROPERTY
1
TestPropertyValue
9
R. Krieg
RKW Solutions
www.rkw-solutions.com
cadman777
Thanx for the input.
What source informed you of that syntax?
Also, I would only use this as a 'last ditch effort', since it breaks the chain of automation.
Imagine having to do that to 1000 DXF files?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Ralf_Krieg
Hello
A simple try and error. I've create a DXf file, added some custom properties with unique names in DGW TrueView (don't have AutoCAD), saved it as copy and afterwards open the dxf with a texteditor comparing the changes to the original version
I think the properties are not part of the standard and not included in Inventor dxf export. You will have to add it in an alternative way.
R. Krieg
RKW Solutions
cadman777
Thanx for doing that work for me!
OK, that's what I thought.
Although there still may be a solution per this thread.
If not, then I may be forced back to AutoLISP (if I can even remember how !).
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
