Create a line in the workplane position on drawing
dialunau
dialunau
Hello everyone,
I have an assembly drawing in which I want to draw a line in the position of a workplane. The problem is that I don't know how to get the workplane coordinates from its position in the drawing view so I can create a line based on that position (so I can view the plane position relative to other parts in the assembly).
Does anyone know a method for this?
My code this far looks like this:
'Get the refference assembly
Dim oAssy As AssemblyDocument
If ThisDoc.Document.AllReferencedDocuments.Item(1).DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
	oAssy = ThisDoc.Document.AllReferencedDocuments.Item(1)
Else
	MsgBox("The Active drawing does not contain an assembly document")
	Exit Sub
Dim oCons As AssemblyConstraint = oAssy.ComponentDefinition.Constraints.Item(1)
Dim oEnt As Object
'Assumming oEnt is a workplane
oEnt = oCons.EntityOne
'Create the sketch
Dim oSheet As Sheet = ThisApplication.ActiveDocument.ActiveSheet
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
Dim oSketch As Sketch
oSketch = oSheet.Sketches.Add()
oSketch.Edit
TomaszDąbrowski
I would create a centerline, use it and make it invisible:
Else
	Exit Sub
Dim oEnt As Object
'Create the sketch
Dim oCL As Centerline = oSheet.Centerlines.AddByWorkFeature(oEnt, oView)
oCL.Visible = False
oSketch.Edit
oSketch.SketchLines.AddByTwoPoints(oCL.StartPoint,oCL.EndPoint)
oSketch.ExitEdit
But in my opinion there is no need to use costraints, better use your workplane directly.
Instead of:
Dim oEnt As Object
You can have:
Dim oEnt As Object
oEnt = oAssy.ComponentDefinition.WorkPlanes.Item("YourWorkPlaneName")
Also please tak notice that such rule will create a new sketch every time you run it.
dialunau
You're right, I don't need to call the constraint.
The code works now, creating the centerline did the trick.
Thank you.
