iProperties from part to assembly
martinhoos
martinhoos
i am looking for a sample code which take custom iProperties from a selected part (code shouldt ask me to select a part) to the assembly.
Thank you in advance...
Regards
Martin
chandra.shekar.g
Autodesk Support
Autodesk Support
@martinhoos,
Try the following iLogic code. Before running code, please update Custom iProperty name in the code and select the part in graphical area.
Dim doc = ThisDoc.Document
If doc.SelectSet.Count = 1 Then
	Dim occ = doc.SelectSet.Item(1)
	Dim name As String = iProperties.Value(occ.Name, "Custom", "Name of custom iProperty")
	MessageBox.Show(name, "Title")
Else
	MessageBox.Show("Part is not selected", "iLogic")
End If
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
martinhoos
Hi Chandra, thank you very much for your reply...  code runs well!
Regards from germay
Martin
