Toggle visibility of objects inside drawings
Hi everyone,
I'm struggling to find a way to toggle the visibility of some objects (images) I have put inside my .IDW.
Do you have an idea to get this with iLogic?
Thank you for you time,
Andrea
mcgyvr
ReferencedOLEFileDescriptor.Visible Property
Parent Object: ReferencedOLEFileDescriptor
Description
Gets/Sets whether the linked/embedded object is visible in the graphics window.
Syntax
ReferencedOLEFileDescriptor.Visible() As Boolean
Property Value
This is a read/write property whose value is a Boolean.
Version
Introduced in version 2011
Hi thanks for your reply,
I tried the following lines to toggle the visibility of one of my objects, but it does not work:
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim aOLERefs() As ReferencedOLEFileDescriptor
ReDim aOLERefs(oDoc.ReferencedOLEFileDescriptors.Count)
Dim iRefCount As Integer
iRefCount = oDoc.ReferencedOLEFileDescriptors.Count
Dim i As Integer
For i = 1 To iRefCount
    aOLERefs() = oDoc.ReferencedOLEFileDescriptors.Item(i)
Next
If aOLERefs(i).DisplayName = "ADX" Then
aOLERefs(i).Visible= False
Next
I got the following error: HRESULT: 0x80004005 (E_FAIL)
Thanks again,
Andrea
