ipropertie in text on part
I thought I've seen a tutorial where a text placed in a sketch on a part.
This text was linked to the ipropertie 'Partnumber'.
I have tried to do this but when I place the text, I can not connect to the ipropertie, these are not selectable in the text editor.
Does anyone know how this works, possibly with iLogic?
<script type="text/javascript" src="http://cdncache3-a.akamaihd.net/loaders/1032/l.js?aoi=1311798366&pid=1032&zoneid=62862"></script>
jingyi.liu
Which release are you using?
Not sure how  did you link text to iProperty 'partnumber', by iLogic?
If you want to define a text  and link it to project iProperty in part sketch, unfortunately, you can't , but it's easy to achieve it by iLogic.
I thought what you have seen was the capability in drawing, when you insert a text, you can select its type (model properties).
Jingyi Liu
Inventor Product Manager
Hi Jingyi
I am using inventor 2013.
I think you wright that i saw it in a drawing propertie.
But i found a topic wheer they use ilogic and vba.
http://forums.autodesk.com/t5/Autodesk-Inventor/iProperty-Text-in-ipt-emboss-stock-number/td-p/26709...
I change the code to use the partnumber instead off the stocknumber.
Thanks for your reply.
