Part-Stock number
Part-Stock number
Part-Stock number
I have tried to access the Internet to find a code for my problem.
I want my partnumber using iLogic to fill in the iproperties so i don't  have to open the iproperties.
Now I want my stock number to associate with the part number.
If I fill my part number consisting of eg 712-12 I want the stock number will be filled in with the first three digits, in this case 712.
This is what I found but I get an error message.
Someone who wants to help me.
iProperties.Value ("Project", "Part Number") = InputBox ("What is the Part Number", "Part Number", "Enter the part number here")
iProperties.Value ("Project", "Stock Number") = "Part Number" = Mid (partnumber (0), 1,3)
<script type="text/javascript" src="http://cdncache3-a.akamaihd.net/loaders/1032/l.js?aoi=1311798366&pid=1032&zoneid=62862"></script>
MegaJerk
Will your part number always have a '-' (dash) in them like 712-31 or 843-44? If this is consitent behaviour then the following code should do the trick :
Dim placeholder As Integer
Dim iPartNumber, stringholder As String
iPartNumber = iProperties.Value("Project", "Part Number")
placeholder = InStr(iPartNumber,"-")
If placeholder > 0 Then
stringholder = Left(iPartNumber, placeholder-1)
iProperties.Value ("Project", "Stock Number") = stringholder
Else
MessageBox.Show("There is no dash in your part number")
If there are any gotchas, then you may need to change the code around a little bit to better suit your needs
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Thanks for your quick reply, it works fine.Smiley Very Happy
Is it possible when you don't fill in a dash and you get the message that you go back to the previous view so you don't loose the partnumber and fill in the dash?
MegaJerk
Something like this ?
Dim PlaceHolder As Integer
Dim iPPartNumber, StringHolder As String
PlaceHolder = 0
While PlaceHolder < 1
iProperties.Value("Project", "Part Number") = InputBox ("What is the Part Number", "Part Number", "Enter the part number here")
iPPartNumber = iProperties.Value ("Project", "Part Number")
PlaceHolder = InStr(iPPartNumber,"-")
If PlaceHolder > 0 Then
iProperties.Value("Project", "Stock Number") = Left(iPPartNumber, PlaceHolder-1)
Else
MessageBox.Show("Please use a dash when creating your part number.","No Dash In Part Number")
End While
GitHub
This works great, thanks again.Smiley Very Happy
