iParts not exporting to Excel... but iAssy works
danny.lewisA9QBW
danny.lewisA9QBW
So I can't figure why the command is working or assembly iAssy but not for the part iPart. Below is the chunk of code to run them. I've attached example files I was using.
Dim Path As String = "C:\TEST\ExportTest"
Dim ExportFile As String = Path & ".xls"
Logger.Info("ExportFile " & ExportFile)
Dim oDoc As Document = ThisDoc.Document
If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
Logger.Info("Assy FileType")
	Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
	If oAsmDoc.ComponentDefinition.IsiAssemblyFactory = True Then
		Logger.Info("Assy iAssemblyFactory Found")
		Dim oiAssyFactory As iAssemblyFactory = oAsmDoc.ComponentDefinition.iAssemblyFactory
		oiAssyFactory.Export(ExportFile, FileFormatEnum.kMicrosoftExcelFormat)
If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
Logger.Info("Part FileType")
	Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
Logger.Info("oPartDoc")
	If oPartDoc.ComponentDefinition.IsiPartFactory = True Then
		Logger.Info("Part iPartFactory Found")
		Dim oiPartFactory As iPartFactory = oPartDoc.ComponentDefinition.iPartFactory
		oiPartFactory.Export(ExportFile, FileFormatEnum.kMicrosoftExcelFormat)
bradeneuropeArthur
Dim ExportFile As String = Path & ".xlsx"
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
use "xlsx" instead of "xls"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
danny.lewisA9QBW
@bradeneuropeArthur
so that works.... but WTF...
why is it .xls for Assemblies (and .xlsx doesn't work) and .xlsx for Parts (And .xls doesn't work)?
Regardless the why... it's working; I'll take it. 🙂
bradeneuropeArthur
That is indeed strange!
@johnsonshiue Do you have any idea why that is the case!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
