iPart rows names problem
Daan_M
Daan_M
Good morning!
I've ran into a problem working with iParts. I located the problem and it was kinda funny once i realized what caused it. I made iPart members with a certain numirical code, consisting of 5 digits in total  (xxx,xx). In a assembly i swap between the iPart variants by filling in the according 5 digit code in Excel.
The problem: Everytime i filled in a 5 digit code in Excel, it seemed to swap to a completely random part and not the part with the according code. See the iLogic below.
The cause: Inventor takes the 5 digit Excel code, and instead of looking for the right membername, it starts looking for a the memberrow. So when i fill in code 197,05, instead of finding the membername '197,05', it goes to row 197 which is code '245,05', see the picture below.
Now is there a easy fix for this? Can i tell iLogic to look for member name instead of member row?
It would save me alot of time, otherwise i have to rewrite my 5 digit code to alphabetical characters.
Cheers, Daan
JhoelForshav
Hi @Daan_M
You can use iPart.FindRow. It automatically changes to the found row aswell. So all you need is something like this to change the row:
iPart.FindRow("Compactmotor", "Member", "=", GoExcel.CellValue(Excelfile, "Sheet1", "B3"))
Daan_M
Thank you for the reply, i think your solution is fitting, but theres a new problem that comes up. See the error message below. Below the pictures ive also posted the entire code.
Excelfile = "C:\Users\Administrator\EMS source.xlsx"
Kasttype = GoExcel.CellValue(Excelfile, "Sheet1" ,"D2")
Dim occ As ComponentOccurrence
Dim ass As AssemblyDocument
ass = ThisDoc.Document
For Each occ In ass.ComponentDefinition.Occurrences
If occ.Name.StartsWith("kast") Then
occ.Suppress
If occ.Name = "kast"&Kasttype Then
occ.Unsuppress
Next
iPart.FindRow("kast"&Kasttype, "Member", "=", GoExcel.CellValue(Excelfile, "Sheet1", "E2"))
d2 = GoExcel.CellValue(Excelfile, "Sheet1", "B5")
iLogicVb.UpdateWhenDone = True
Excelnamevalue = GoExcel.CellValue(Excelfile, "Sheet1", "B6")
Stepfilename = Excelnamevalue
ThisDoc.Document.SaveAs("C:\Data\Output\" & Stepfilename & ".stp", True)
JhoelForshav
@Daan_M
Maybe your exceldocument doesn't return a string and thats the problem...
Try using .ToString and see if it helps.
iPart.FindRow("Compactmotor",  "Member", "=", GoExcel.CellValue(Excelfile, "Sheet1", "B3").ToString)
Daan_M
That made it work! Thank you for the quick and helpfull support.
