VBA / API - how to iterate through all Components of .IPN
fullevent
Advisor Advisor
Message 1 of 13
fullevent
I'm trying to find a way to go through all PublicationComponents of an .ipn to find a specific one by name.
I have the following information:
FullFileName of the .ipn and the
name of the component (e.g. "00009 - Sechskantschraube:1")
What I need is the Rangebox of that Component.
2020-05-29 11_00_45-Microsoft Visual Basic for Applications - Default.ivb [break].png
I can access the document via the .Parent property, but unfortunately not in the same way from the document to the component.
There is no "Publication" propertyThere is no "Publication" property
...so how can I find the PublicationComponent in an IPN only by knowing the name?
Is there a way?
Best regards
Aleksandar Krstic
Produkt- und Projektmanager
Replies (12)
Message 2 of 13
fullevent
I have a sample data set, which I can send via pm if desired.
Unfortunately I still haven't found a possible solution.
If someone wants to try this and needs the sample data, just let me know.
Would be great to get some support for this issue. Thanks in advance.
Best regards,
Aleksandar Krstic
Message 3 of 13
marcin_otręba
Try this for start:
Dim ipn As PresentationDocument
 ipn = ThisApplication.ActiveDocument
Dim odoc As AssemblyDocument
 odoc = ipn.ReferencedDocuments.Item(1)
Dim occ As ComponentOccurrence
occ = odoc.ComponentDefinition.Occurrences.ItemByName("your name")
and for traverse trough all occ:
For Each occ In odoc.ComponentDefinition.Occurrences
Debug.Print occ.Name
Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 4 of 13
fullevent
Hello @marcin_otręba,
first of all thank you for your time.
Your code gets me the componentOccurrence of the iam. That's not quite what I'm trying to do.
I am trying to find the PublicationOccurrence of an IPN.
But I can't find a way to go through all PublicationOccurrences of an IPN.
I expected to do something along those lines.
Dim occ As PublicationOccurrence
For Each occ In oIPN.PublicationOccurrences 'but it does not exist
Next
Maybe you have another idea?
regards,
Aleksandar Krstic
Message 5 of 13
marcin_otręba
Something like this ?
Dim oDoc As PresentationComponent
 oDoc = ipn.ActiveScene.TopSceneComponent
Dim osub As PresentationComponent
For Each osub In oDoc.SubComponents
MessageBox.Show(osub.Name, "Title")
Next
Message 6 of 13
fullevent
This is going in the right direction! Thanks a lot for the help.
The reason why I want to find PublicationOccurrence is because I want to check the rangebox.
It seems the PresentationOccurrence has no rangebox or is there a way to get it by the PresentationOccurrence?
Aleksandar Krstic
Message 7 of 13
marcin_otręba
what you want to get from rangebox? position? size?
Message 8 of 13
fullevent
I need the MaxPoint and the MinPoint.. so i need all 6 values.
Aleksandar Krstic
Message 9 of 13
marcin_otręba
Try something like code below only be careful it will not work for subcomponents type assemblies, in tjhhis scenario you must go deeper to subcomponent of that component.
On Error Resume Next
If osub.SubComponents.Count = 0 Then
Debug.Print osub.Name & " " & osub.SurfaceBodies.Item(1).RangeBox.MaxPoint.X & " " & osub.SurfaceBodies.Item(1).RangeBox.MaxPoint.Y & " " & osub.SurfaceBodies.Item(1).RangeBox.MaxPoint.Z
Else
Dim osub1 As PresentationComponent
For Each osub1 In osub.SubComponents
Debug.Print osub1.Name & " " & osub1.SurfaceBodies.Item(1).RangeBox.MaxPoint.X & " " & osub1.SurfaceBodies.Item(1).RangeBox.MaxPoint.Y & " " & osub1.SurfaceBodies.Item(1).RangeBox.MaxPoint.Z
Next
Next
Message 10 of 13
fullevent
That looks very good. Thank you a lot.
..confusing.. I'm getting different values... here for comparison:
Max Points using your Code:
MaxPoints of "PublicationOccurrence.Rangebox"
I'm not sure what the difference is between the two. Right now I don't even know which range box is the right one. I will try to find out tomorrow and get back to you.
Thanks for your support!
Best regards,
Aleksandar Krstic
Message 11 of 13
fullevent
I was able to test your code and I got exactly the rangebox I was looking for. Thank you!
The initial question is not answered, but now I also know that the question would not have led to my goal.
..Sometimes you do not know what you are looking for until you find it.
*deep*😎🤣
Have a nice day!
Aleksandar Krstic
Message 12 of 13
edv
is it possible to make the script work for IV2016?
Because there is no PresentationComponent or ActiveScene
Message 13 of 13
marcin_otręba
sorry, i do not have 2016.. also i think it is not possible due fact that it was introduced in 2018.
