change color and thickness of sketch line
Message 1 of 11
I want change properties (color and thickness) of sketch line in assembly/part, when I have open assembly,but not active sketch.
Rule:
Dim oSketch as Sketch
oSketch=thisApplication.ActiveEditObject   ´here is a problem, because rule run only when is sketch active!!!
Dim oColor as color
oColor = thisApplication. TransientObject.CreateColor(0,0,0)
osketch.SketchLines(2).OverrideColor=oColor
Question are:
1) How will run rule, when is sketch not active, but I have assembly/part open?
2) How change thickness of sketch line??
3) Where/how find out how is named this line/curve in sketch?? ( SketchLines(2) or SketchLines(99) )
4) command for white color??
Thanks for your time and reply!
Replies (10)
Message 2 of 11
JhoelForshav
Hi @Anonymous
To get your rule to run, I'd recommend getting the sketch by its name:
Dim oDoc As Document = ThisDoc.Document
Dim oSketch As PlanarSketch = oDoc.ComponentDefinition.Sketches.Item("sketch name") 'sketch name = Name of sketch
Dim oColor As Color
oColor = ThisApplication.TransientObjects.CreateColor(255, 255, 255) 'White
Dim oLine As SketchLine = oSketch.SketchLines(2)
oLine.OverrideColor = oColor
oLine.LineWeight = 2 'Set Lineweight
Identifying a specific line is a bit difficult. You could use RefKeys like @Anonymous is doing here:
https://forums.autodesk.com/t5/inventor-customization/change-sketch-constraints-programmatically-ilogic/td-p/9542773
If you have the sketch visible though, maybe it's enough to just have the user pick the line like this?
'Get the sketchLine
Dim oLine As SketchLine = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveLinearFilter, "Pick the sketchline")
'Set the color
oLine.OverrideColor = ThisApplication.TransientObjects.CreateColor(255, 255, 255)
'Set the line weight
Message 3 of 11
Hi  JhoelForshav,
I have tried your first code. and I have error in the rule. - Memember not found......
I think, that problem is in this row:
 Do you know why?
Message 4 of 11
JhoelForshav
@Anonymous
You must replace "sketch name" with the name of the sketch that the line is in 🙂
Ex:
Dim oSketch As PlanarSketch = oDoc.ComponentDefinition.Sketches.Item("Sketch1")
Message 5 of 11
JhoelForshav
Or did I misunderstand maybe. Do you want to run the rule from an assemmbly and find a sketch by a specific name in any of the occurrences in the assembly?
Then something like this maybe?
This rule changes the color and thickness of sketchline(2) in all sketches with the selected name within any component in the assembly.
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oSketchName As String = "Sketch1" 'Name of the sketch
For Each oRefDoc As Document In oAsm.AllReferencedDocuments
	If oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject
	If oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefDoc).Count > 0
		Try
			Dim oSketch As PlanarSketch = oRefDoc.ComponentDefinition.Sketches.Item(oSketchName) 'sketch name = Name of sketch
			Dim oColor As Color
		Catch
			'Sketch is not in document or Sketchline with selected index not in sketch
		End Try
Next
iLogicVb.UpdateWhenDone = True
Message 6 of 11
Yes I know. This I did and I have this error
Message 7 of 11
JhoelForshav
@Anonymous
Did you see my last post? 🙂
Message 8 of 11
now yes. I´m trying it
Message 9 of 11
Ok. I have tangled head.
First I want say that second rule is ok - run. no problem
First rule: I made part- .ipt. I created rectanguler sketch and model. This rule I have tried on rectangle sketch.
when I have open only this part. This rule write error with membernotfound...
Then I have tried the last (third rule) - I made assambly- .iam . I put the part with rectangle sketch. I have tried third rule on sketch of part. No problem. This rule run.
then I have tried made only rectanguler sketch in assambly with part. And first rule I put in the assambly and run!.
Then I found out that when I have open assembly and I open part. - First rule run in part (but condition is that you must have open assembly)
Then I tried closed all files and open only part and first rule wrote error with memeber
So it means I don´t know why, that first rule run in part, when I have open assembly with part.
Do you know why??
Do you understand me what I mean? 😄
Message 10 of 11
JhoelForshav
I think I understand what you want now.
Try this:
Sub Main
	updateLine(ThisDoc.Document, oSketchName)
	If ThisDoc.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject
					updateLine(oRefDoc, oSketchName)
		Next
End Sub
Sub updateLine(oDoc As Document, oName As String)
	Try
		Dim oSketch As PlanarSketch = oDoc.ComponentDefinition.Sketches.Item(oName) 'sketch name = Name of sketch
		Dim oColor As Color
	Catch
	End Try
End Sub
Message 11 of 11
Ok. Thanks for your help.
Only for information in assembly works all your command. In part I have problem with first rule....
The last question (this week 🙂 ).
 1. command for change style of line in chart ?
nice a weekend
