Change sketch constraints programmatically [iLogic]
I have two reference lines, with different angles, 4 deg & 10 deg. The first line has length of KnuckleDist = 1000.
A rectangle shape is constrained to PlateDistance = 800mm from origin, and one side of the rectangle has a Collinear Constraint to the first reference line.
I would like to programmatically re-constrain the rectangle with Collinear Constraint to first Reference Line if KnuckleDistance > PlateDistance and to second Reference Line if KnuckleDistance < PlateDistance (so that the rectangle is always resting on the Reference Line beneath it).
Can this even be done with iLogic?
JhoelForshav
Hi @Anonymous
It's possible for sure. Can be difficult though depending on the complexity of your sketch. You need to figure out how to identify the lines. I made a simple example part for you with a rule in it that toggles a collinear constraint between two differrent reference lines. See attached ipt.
@JhoelForshav Thanks, but I am unable to open the file (Using Inventor 2019). Could you please paste the code, and I'll hopefully be able to piece it together?
JhoelForshav
Hi @Kenny.P
Too bad you couldn't open the file. The code is and has to be very specific to the sketch entities within the sketch. As i said, it can be a bit tricky to identify the sketchlines you want to use...
Anyways, here goes:
Dim oDoc As PartDocument = ThisDoc.Document
Dim oSketch As PlanarSketch = oDoc.ComponentDefinition.Sketches.Item("Sketch2")
Dim oLine As SketchLine
Dim oPrevRefLine As SketchLine
For Each oConstraint As GeometricConstraint In oSketch.GeometricConstraints
 If oConstraint.Type = ObjectTypeEnum.kCollinearConstraintObject
  oLine = oConstraint.EntityOne
  oPrevRefLine = oConstraint.EntityTwo
  oConstraint.Delete
  Exit For
Next
For Each sLine As SketchLine In oSketch.SketchLines
 If sLine.Reference AndAlso sLine IsNot oPrevRefLine
  oSketch.GeometricConstraints.AddCollinear(oLine, sLine)
  Exit For
Next
iLogicVB.UpdateWhenDone = True
Thank you @JhoelForshav , the code makes sense, and the clip is helpful!
I think what I will need to do is write a separate rule that returns the ReferenceKey of a selected SketchLine, and save hardcoded ReferenceKeys of the three relevant SketchLines in my code.
Then at runtime, I can use the ReferenceKeys to find which constraints to remove, and to create new constraints.
It seems a bit tricky, but I think it should work.
So with help from @JhoelForshav's code, I got it working the way I wanted.
Posting my code here in case others have use for it. (I found many people asking similar questions)
' Select a SketchLine in the window and run this rule to get the RefKey
Class GetSketchLineRefKey
	Sub Main
		Dim oSketchLine As SketchLine = oDoc.SelectSet(1)
		Dim refKey() As Byte
		refKey = New Byte() {}
		Call oSketchLine.GetReferenceKey(refKey)
		Dim strKey As String
		strKey = oDoc.ReferenceKeyManager.KeyToString(refKey)
		Logger.Info("Line Refkey: " & strKey)
	End Sub
End Class
Then replace the RefKey Strings in rule below with the ones you receive from previous code:
Class ReconstrainSketch
	Sub Main
		oDoc = ThisDoc.Document
		'[ Enter RefKey for lines from SketchLineRefKey rule strings manually
		Dim oMovingLine As SketchLine	= RefKeyStringToObject("EAIAABAAAABSAAAAAAAAAIAAAAAAAAAA")
		Dim oRefLine1 As SketchLine 	= RefKeyStringToObject("EAIAABAAAAAXAQAAAAAAAIAAAAAAAAAA")
		Dim oRefLine2 As SketchLine		= RefKeyStringToObject("EAIAABAAAAAwAQAAAAAAAIAAAAAAAAAA")
		For Each oConstraint In oMovingLine.Constraints
			If (oConstraint.Type = ObjectTypeEnum.kCollinearConstraintObject)
				Dim oLine1 As SketchLine = oConstraint.EntityOne
				Dim oLine2 As SketchLine = oConstraint.EntityTwo
				If (KnuckleDistance < PlateDistance) And ((oLine1 Is oMovingLine And oLine2 Is oRefLine1) Or (oLine1 Is oRefLine1 And oLine2 Is oMovingLine)) Then
					Logger.Info("Reconstraining 1")
					oConstraint.Delete
					oSketch.GeometricConstraints.AddCollinear(oMovingLine, oRefLine2)
					Exit For
				Else If (KnuckleDistance > PlateDistance) And ((oLine1 Is oMovingLine And oLine2 Is oRefLine2) Or (oLine1 Is oRefLine2 And oLine2 Is oMovingLine)) Then
					Logger.Info("Reconstraining 2")
					oConstraint.Delete
					oSketch.GeometricConstraints.AddCollinear(oMovingLine, oRefLine1)
					Exit For
		Next
	iLogicVb.UpdateWhenDone = True
	End Sub
	Function RefKeyStringToObject(strKey As String) As Object
		Call oDoc.ReferenceKeyManager.StringToKey(strKey, refKey)
		Dim obj As Object = oDoc.ReferenceKeyManager.BindKeyToObject(refKey)
		Return obj
	End Function
End Class
I'm not fond if the following code:
but I found no better way at the moment.
