Ipart = Publish Part = Part - Data
iva.btblan
Message 1 of 13
iva.btblan
Can anyone help me to solve this link between files problem.
I don't know how to do it.
I want to keep the ipart information: Material, Espessura, and code the same in the part.
Extracted: Publish part.
At the end ipart = publish part = part.
Replies (12)
Message 2 of 13
A.Acheson
Hi @iva.btblan
Could you give some screenshots of what you want to achieve? List out the operations in bullet points and include any code if this is needed.  I cannot open the file due to inventor version.
Regards
Alan
Message 3 of 13
iva.btblan
Sorry, I'm looking for an older version in the company to send you the subject, please wait. thanks.
Message 4 of 13
iva.btblan
Here is the file in a previous version.
I can't keep the link between the ipt and iam files.
I don't know how to do that!
Keep the changes in iam and ipt. Equal.
Message 5 of 13
A.Acheson
Is it possible to explain the issue with images? What code are you using and what are the steps to produce the error? I am not near a computer now to open the zipped files. I think you will get more help if you can explain the situation
Regards
Alan
Message 6 of 13
iva.btblan
I attach the explanatory figures. and the IPT file
Message 7 of 13
A.Acheson
I had a look at you images, unfortunately the images are a little difficult to read. I can see that you publish the part to content center and now the descriptions do not match when you change size, correct? This could be the interaction between content center and change size command. Is their ilogic being used to create the description or are you using description expression? Can you please post images of the description for the initial place from content center and then the next change in size that is wrongly shown in the description?
Regards
Alan
Message 8 of 13
iva.btblan
Here is a new explanation. Was I able to explain?
Message 9 of 13
A.Acheson
Is the issue that the fraction imperial thickness "3/16" is displayed as decimal mm ? You could change this to a text unit to avoid this conversion. Or alternatively open the content center and change the unit of the column to inch and fraction.
Regards
Alan
Message 10 of 13
iva.btblan
Here's a new PDF file.
Message 11 of 13
iva.btblan
Can anyone help with this problem?
Message 12 of 13
A.Acheson
Hi @iva.btblan
I'm not sure I understand the information being displayed. A video of the issue might explain the issue further. Can you provide that? I don't entirely see the relevance of showing the ipart table referencing because the custom publish part reacts in a different way because the iproperties are now controlled from the content center table and then can be edited manually in the custom part itself.
Have you ilogic code running in the part that you haven't shown or is the information only coming from the built in iproperties?
Regards
Alan
Message 13 of 13
A.Acheson
I think I understand your issue. You would like several parameters/iproperties to change based on thickness and material change in the form correct? You would like ipart functionality in the custom format. I assume trying to change the material from the content center will erase your custom parameter sizes correct?
This rule will automatically change the CODIGO parameter based on conditions being true. The down side of this method is the code is in each file.
If Espessura = "3/8" AndAlso iProperties.Material = "ASTM A36" Then
	CODIGO = "05.022.01.003.0005"
ElseIf Espessura = "1/2" AndAlso iProperties.Material = "ASTM A36" Then
	CODIGO = "05.022.01.003.0004"
End IF
 This rule here will allow you to change the  CODIGO parameter from external rule. The down side of this method is that it needs to be manually run on the document to update the parameter
If Parameter("Espessura") = "3/8" AndAlso iProperties.Material = "ASTM A36" Then
	Parameter("CODIGO") = "05.022.01.003.0005"
ElseIf Parameter("Espessura") = "1/2" AndAlso iProperties.Material = "ASTM A36" Then
	Parameter("CODIGO") = "05.022.01.003.0004"
End IF
Regards
Alan
