close all opened drawings
m.magini
m.magini
I have some drawings open in my inventor session.
I'd to run a macro saved in one file called "rule".dwg
macro simply gets the file name, display it with message box
and then close the "processed" file if it is not the "rule" one.
At th end only "rule" drawing will remain open.
I have some proble with close command line
oDocument.Close does nothing.
ThisApplication.Document.close returns error
Thanks for helping
' Declaration
Dim oDocument As DrawingDocument
' Starting cycle
For Each oDocument In ThisApplication.Documents.VisibleDocuments
' Get file name
Dim myoutputname As String
myoutputname = System.IO.Path.GetFileNameWithoutExtension(oDocument.FullFileName)
'Code
	If myoutputname <> "rule" Then
			MessageBox.Show(myoutputname, "Title")
			'oDocument.Close'????????
	Else
			MessageBox.Show("This file contains the rule", "Title")
'end for each cycle
Next
Andrii_Humeniuk
Hi @m.magini . In my case the code works fine. Maybe it's because I'm specifying True or False for the SkipSave value in the Close() method.
' Declaration
' Starting cycle
	' Get file name
	'Code
		Else
	'end for each cycle
	oDocument.Close(True)
Next
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
m.magini
Thanks, it works for me too now.
Thank you
Bye
