iPart.FindRow in VBA
damian_dymczyk
damian_dymczyk
Hello All, I'm trying to compose a code to create a new member of iPart straight from Assembly. Macro is doing what it should and for each iPart component is adding new row with value taken from user Parameter of assembly. My problem start when I have two iParts from the same iPartFactory, I end up with two iParts with the same value. I know that in iLogic there is a snippet Part.FindRow that would suit perfect to make an If condition, that when it's true row would change to existing else new row would be created. I cannot find similar solution in VBA. Can I count on your help?
Here is the code
Sub AddNewMember()
'originally determin variables
Dim oCompDef As Inventor.ComponentDefinition
Set oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oCompOcc As ComponentOccurrence
Dim oFerCompDef As ComponentDefinition
Dim oiPart As iPartMember
' Get the active document. This assumes it is a assembly document.
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
' Get the Parameters collection.
Dim oParams As Parameters
Set oParams = oDoc.ComponentDefinition.Parameters
' Get the Parameter called "Length"
Dim oParam As Parameter
Set oParam = oParams.Item("Test1")
' Get the value of the parameter. This value is in the
' internal units of Inventor. If the parameter defines
' a length unit then the value is always returned in
' centimeters.
Dim dLength As Double
dLength = oParam.Value * 10
Debug.Print dLength
Dim oW As String
oW = CStr(dLength)
Debug.Print oW
For Each oCompOcc In oCompDef.Occurrences
If oCompOcc.IsiPartMember = True Then
    Dim definitionMember As PartComponentDefinition
    Set definitionMember = oCompOcc.Definition
    Dim iPartMember As iPartMember
    Set iPartMember = definitionMember.iPartMember
    Dim factory As iPartFactory
    Set factory = iPartMember.ParentFactory
    Dim doc As PartDocument
    Set doc = factory.Parent
    Dim defintionFactory
    Set definitionFactory = doc.ComponentDefinition
    Debug.Print doc.FullFileName
     ' Open the factory document invisible.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Open(doc.FullFileName, False)
    On Error Resume Next
    Dim oFactory As iPartFactory
    Set oFactory = oPartDoc.ComponentDefinition.iPartFactory
    'Get the iPartTable
'    If Err > 0 Or oFactory Is Nothing Then
'    Exit Sub
'    End If
'   Get the part number used in the iPart table
    Dim row As iPartTableRow
    Set row = oFactory.TableRows.Item(oFactory.TableRows.Count)
    Dim sPartNumber As String
    If Not row Is Nothing Then
        sPartNumber = row.MemberName
    Dim pos As Integer
    pos = InStrRev(sPartNumber, "-")
    Dim str As String
    str = Left(sPartNumber, pos)
    Member = Left(sPartNumber, pos - 1)
    Dim iNumber As Integer
    iNumber = Right(sPartNumber, Len(sPartNumber) - pos)
    'Assume the off of the parameter's value (between two rows) is 0.5cm
    Dim off As Double
    off = 0.5
    Dim oWorkSheet
     Set oWorkSheet = oFactory.ExcelWorkSheet
    Dim oCells
     Set oCells = oWorkSheet.Cells
    ' New row's value...
    If (iNumber + 1) < 100 Then
        sPartNumber = str + "0" + CStr(iNumber + 1)
    Else
        sPartNumber = str + CStr(iNumber + 1)
    Dim oCell
     oCell = oCells.Insert(, True)
    oCells.Item(row.Index + 2, 1) = sPartNumber
    oCells.Item(row.Index + 2, 2) = Member
    oCells.Item(row.Index + 2, 3) = oW
   ' oCells.Item(row.Index + 2, 7) = "Include"
    Dim oUM As UnitsOfMeasure
     Set oUM = oPartDoc.UnitsOfMeasure
ThisApplication.CommandManager.ControlDefinitions.Item("DimensionDisplayEqn").Execute
    Dim i As Integer
    Dim oParameter As Parameter
    For i = 4 To 4 + oPartDoc.ComponentDefinition.Parameters.UserParameters.Count
        Set oParameter = FindParameterByName(oPartDoc, oCells.Item(1, i).Formula)
        If oParameter.Name <> oPartDoc.ComponentDefinition.Parameters.UserParameters.Item(4).Name Then
            oCells.Item(row.Index + 2, i) = oUM.GetStringFromValue(oParameter.Value + off * (row.Index), oParameter.Units)
        Else
            oCells.Item(row.Index + 2, i) = oPartDoc.ComponentDefinition.Parameters.UserParameters.Item(4).Expression
    Next
    Set oUM = Nothing
    Dim oWB
     Set oWB = oWorkSheet.Parent
    oWB.Save
    oWB.Close
    MsgBox ("Add a row - done!")
Next
End Sub
Function FindParameterByName(oP As PartDocument, Nazwa As String) As Parameter
Dim i As Long
For i = 1 To oP.ComponentDefinition.Parameters.UserParameters.Count
If UCase(oP.ComponentDefinition.Parameters.UserParameters.Item(i).Name) = UCase(Nazwa) Then
    Set FindParameterByName = oP.ComponentDefinition.Parameters.UserParameters.Item(i)
    Exit For
Next
End Function
A.Acheson
Hi @damian_dymczyk
So it looks like your searching through the factory table which is correct. Where are you having the trouble? Were you able to find the cell value if it exists?
Regards
Alan
damian_dymczyk
In iLogic I would use z =iPart.FindRow(doc.FullFileName, "ModuleLength", "=", oW, "Position", "=", "Horizontal") but I want to make it in VBA for exercises and I got stuck. I don't know how to find row and make it active when two cells need to be matched.
    Dim oCells
    'So here I know that I need to have  if condition that will check two columns
 for values that are equal parameters I declare in the assembly then  true then do nothing
else
code will start adding new row to iPartFactory
A.Acheson
There is probably a few ways to go about this but how about a function to check the column and rows for the presence of the value. If none found return -1. You can then compare against another column  and see if the row matches. If you have non unique data in the columns you might need to add the row number to a list of string  for each columns and compare the two lists. I haven't factored that in with the below function. there might even be a better way if you search the issue with excel VBA forums. Here is where I got most of the function layout.
A = GetRowIndex(oFactory, "Part Number", "Enter a cell Value to check")
    MsgBox (A)
Private Function GetRowIndex(ByVal Factory As iPartFactory, _
                                ByVal ColumnName As String, ByVal RowValue As String) As Long
    ' Iterate through all of the columns looking for a
    ' match to the input name.
    Dim i As Long
    For i = 1 To Factory.TableColumns.Count
        Dim oColumn As iPartTableColumn
        Set oColumn = Factory.TableColumns.Item(i)
        ' Compare this column with the input name.
        If LCase(oColumn.DisplayHeading) = LCase(ColumnName) Then
            ' A matching column was found so check the row value.
           For j = 1 To Factory.TableRows.Count
            Dim oRow As iPartTableRow
            Set oRow = Factory.TableRows.Item(j)
            If RowValue = oRow.Item(j).Value Then
                GetRowIndex = j
                Exit Function
            Next
    Next
    ' The row wasn't found so return -1.
    GetRowIndex = -1
End Function
Regards
Alan
damian_dymczyk
Hi @A.Acheson thanks for the reply I manage to add the function to the code but when I run it the MsgBox(A) display empty box. I'm really suprise that snippet is not available in VBA I even made a small research and find this IiPartRowChanger.FindRow Method
but I don't even know when to start to create this function.
Sub x()
' centimeters.
Debug.Print dLength
Dim oW As String
oW = CStr(dLength)
Debug.Print oW
    Dim Factory As iPartFactory
    Set Factory = iPartMember.ParentFactory
    Set doc = Factory.Parent
    'Get the iPartTable
'    Exit Sub
'    End If
    Dim pos As Integer
    Dim str As String
    Dim off As Double
    off = 0.5
    Dim oWorkSheet
    Dim oCells
     A = GetRowIndex(oFactory, "ModuleLength", oW)
    MsgBox (A)
    Else
    Dim oCell
    Dim i As Integer
        Else
    Next
    Set oUM = Nothing
    Dim oWB
    oWB.Save
    oWB.Close
Next
End Sub
Dim i As Long
    Exit For
Next
End Function
    Dim i As Long
                GetRowIndex = j
                Exit Function
            Next
    Next
    GetRowIndex = -1
End Function
A.Acheson
Maybe ensure the variable is declared as long. I ran the code exactly as you have it and it returns -1 for non existing parameter.
Yes I am not sure about using IiPartRowChanger.FindRow Method in VBA.
Regards
Alan
damian_dymczyk
Hello All, after a bit of research I came to the conclusion that it is waaaay more convenient to do with iLogic. I refer to this forum post where my struggle is solved in 3 lines of code:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/iparts-and-member-part-naming-using-...
Thank you @A.Acheson for your input!
