Checkout dialogue selection or suppress
sellis
sellis
I have an excel addin that opens and prints drawing from a list. Current issue is the Vault checkout dialogue pops up or default selection is made that could be to check out. I need the drawing to not be checked out as no changes are to be saved.
From excel VB.net addin I get file from vault and open the drawing with
Inventor.Document = InventorApplication.Documents.Open(FilePath, True)
Is there a way to ensure drawing is opened without being checked out and no dialogue interruption?
Zach.Stauffer
The only way I know of is to deactivate the Vault Addin before trying to open the files, then reactivating it when done.
Dim vaultAddin As ApplicationAddIn= inventApp.ApplicationAddIns.ItemById("{48B682BC-42E6-4953-84C5-3D253B52E77B}")
vaultAddin.Deactivate
'Do your printing here
vaultAddin.Activate
sellis
That worked great.
Thanks!
Skadborg.NTI
Are there any other ideas to solve this problem? I have occasionally used the trick mentioned above to temporarily deactivate the Vault add-in. However, sometimes Inventor crashes when I reactivate the add-in.
Any alternative suggestions would be greatly appreciated.
g.georgiades
InventorApplication.SilentOperation=True does not work for vault prompts.
The only way I can think of is to re-configure the vault prompts manually and then set them back to their original values when you are done.
See this post for how you can edit the vault prompts yourself.
https://forums.autodesk.com/t5/inventor-programming-ilogic/is-there-a-why-to-change-promt-or-not-bei...
