Updating Assembly with iLogic rule problems
ballenZXFHH
ballenZXFHH
I have an assembly that I have been working on and has been working fine so far through all the parts I have added until now. as soon as I add another part the Ilogic rule (that I got from the internet) doesn't work right. In the screencast I show how I add Pc# 12 and it gives me the error. its not just this part, its anything I try to add. Any help would be great.  This is the link to a screencast I made of my problem.        Screencast
Public Sub Main()
	CopyUserParams()
End Sub
Private Sub CopyUserParams()
    If ThisDoc.Document.DocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
        MsgBox("The active document must be an assembly.")
        Return
    Dim asmDoc As Inventor.AssemblyDocument = ThisDoc.Document
    For Each refDoc As Inventor.Document In asmDoc.AllReferencedDocuments
        ' Look for part documents.
        If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
            Dim partDoc As Inventor.PartDocument = refDoc
            Dim refDocUserParams As UserParameters = partDoc.ComponentDefinition.Parameters.UserParameters
            ' Add the assembly parameters to the part.
            For Each asmUserParam As UserParameter In asmDoc.ComponentDefinition.Parameters.UserParameters
                ' Check to see if the parameter already exists.
                Dim checkParam As UserParameter = Nothing
                Try
                    checkParam = refDocUserParams.Item(asmUserParam.Name)
                Catch ex As Exception
                    checkParam = Nothing
                End Try
                If checkParam Is Nothing Then
                    ' Create the missing parameter.
                    refDocUserParams.AddByExpression(asmUserParam.Name, asmUserParam.Expression, asmUserParam.Units)
                Else
                    ' Update the value of the existing parameter.
                    checkParam.Expression = asmUserParam.Expression
            Next
    Next
	iLogicVb.UpdateWhenDone = True
End Sub
Yadow
I may be dumb here, but what userparameters does the placed symbol have? Maybe you need to re-define some UserParams in the part before running the code.
ballenZXFHH
Parameters match exactly across the part and the assembly. I can put in just a simple part with no user parameters and get the same error.
BDCollett
I wonder if it is related to an active Model State causing the error? Just a guess.
ballenZXFHH
Sorry, but I'm not sure what you mean by that
johnsonshiue
Hi! If you create a brand new part, does it work? It seems to work for me. Maybe the part is a CC part or a library part, which is readonly. Please share the file you downloaded. Forum experts can help take a look.
Many thanks!
Software Test Engineer
