Invoke Edit Feature command
I want to launch the Edit Feature interface for editting by the user.  I was hoping for a PartFeature.Edit method, but no such luck.
Is there a workaround or something I am missing?  I am will need this for Holes, fillets and extrudes.
sanjay.ramaswamy
Here's the code to put an extrude feature in edit mode...
Sub EditFeature()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oFeature As ExtrudeFeature
    Set oFeature = oDef.Features.ExtrudeFeatures.Item(1)
    Call oDoc.SelectSet.Select(oFeature)
    Dim oCtrlDef As ControlDefinition
    Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("EditExtrudeCtxCmd")
    oCtrlDef.Execute
End Sub
The names (such as "EditExtrudeCtxCmd")  for the various edit feature commands can be found by executing this macro and searching the resulting text file...
Sub PrintCommandNames()
    Dim oControlDefs As ControlDefinitions
    Set oControlDefs = ThisApplication.CommandManager.ControlDefinitions
    Dim oControlDef As ControlDefinition
    Open "C:\temp\CommandNames.txt" For Output As #1
    Print #1, Tab(10); "Command Name"; Tab(75); "Description"; vbNewLine
    For Each oControlDef In oControlDefs
        Print #1, oControlDef.InternalName; Tab(55); oControlDef.DescriptionText
    Next
    Close #1
End Sub
Perfect.
Thank you Sanjay.
Jeff
