ModelParameter to DimensionConstraint
Hi.
Can anyone tell me how to convert model parameters (which are actually created while constraining the sketch)  to DimensionConstraints
Thanks in advance,
Sundeep
sanjay.ramaswamy
There isn't an easy way to go from a parameter to the owning constraint. The brute force way is to iterate over all dimension constraints and compare the Parameter object returned by DimensionConstraint.Parameter to the object that you have.
Hi Sanjay,
Thanks for the reply,
The actualy scenario is the sketch is from the iFeature, so when i iterate through the DimensionsConstraints and get the parameter, it fails and this is the error:
 oDimensionConstraint.Parameter {"The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"} Inventor.Parameter
Here's the code i use to iterate through the iFeatures:
Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinitionFor Each oiFeature As iFeature In oFeatures.iFeatures
Dim oDimsToRetrive As ObjectCollection
oDimsToRetrive = _InventorApp.TransientObjects.CreateObjectCollection()
            For Each oiFeatSketch As Sketch In oiFeature.Sketches
                     For Each oDimensionConstraint As DimensionConstraint In oiFeatSketch.DimensionConstraints
                                   If oDimensionConstraint.Parameter.Name.ToUpper.Contains("FAB")  Then
                                           oDimsToRetrive.Add(oDimensionConstraint)
                      Next
           Next
Next
Thank You,
Sundeep
sanjay.ramaswamy
That does seem to be a problem in the API. The DimensionConstraint.Parameter property fails for all constraints within an iFeature sketch. I've filed this issue in our database.
Unfortunately, I don't know of any workarounds. Sorry.
Sanjay,
Thank you for your help.
I will try to find a workaround for that and will keep you posted and please let me know in case you find any too.
Thanks again,
Sundeep
