Invisible parts in drawings
kresh.bell
kresh.bell
is it possible to create iLogic that in drawings will make invisible all parts coming from eg a specific folder from library?
JelteDeJong
i guessed to you mean a folder on your drive. if that is the case try this script. if you want to hide files from an other folder then change the variable "textToSearchFor "
Dim textToSearchFor As String = "\forum\"
Dim view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select view")
Dim assembly As AssemblyDocument = view.ReferencedDocumentDescriptor.ReferencedDocument
For Each occ As ComponentOccurrence In assembly.ComponentDefinition.Occurrences
    Dim fileName As String = occ.ReferencedFileDescriptor.FullFileName
    If (fileName.Contains(textToSearchFor)) Then
        For Each curve As DrawingCurve In view.DrawingCurves(occ)
            For Each segment As DrawingCurveSegment In curve.Segments
                segment.Visible = False
            Next
        Next
    End If
Next
Jelte de Jong
Blog: hjalte.nl - github.com
kresh.bell
absolutely fantastic, works great.
Is it possible to edit this iLogic to hide all parts that have the prefix "-" in the solid bodies name? All my hols make parts with the prefix "-"  in the solid bodies name and in drawing are in reality redundant.
JelteDeJong
Sub Main()
        Dim occDoc As Document = occ.Definition.Document
        If (occDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
            Dim partDoc As PartDocument = occDoc
            Dim name As String = partDoc.ComponentDefinition.SurfaceBodies.Item(1).Name
            If (name.StartsWith("-")) Then
                hideOccurence(view, occ)
            End If
        End If
    Next
End Sub
Private Sub hideOccurence(view As DrawingView, occ As ComponentOccurrence)
        Next
    Next
End Sub
this rule will only work if the first body has the prefix.
Jelte de Jong
kresh.bell
extraordinary !!!! It works great. Thanks again
kresh.bell
I found one minor problem. Can you fix it?
iLogic works great if solid with the prefix "-" is not part of subassembly.
I'll point to an example of a drawer.
It works for this solid
It doesn't work for this solid
in drawing it looks like this
