❗ - INVGEN-63057 broke my code in Inventor 2023.2
CattabianiI
CattabianiI
I used to edit iProperties of ipart/iAssembly instance via iLogic/addIn, and now is not possible anymore:
Blocked changing an ipart/iassembly instance display name and iproperties from API. INVGEN-63057
Why? I need a way to do it again as soon as possible!
bradeneuropeArthur
Could you share the code and the file for testing.
Look not ideal.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
CattabianiI
It's very easy to reproduce.
Open an assembly containing an iPart member (not a custom one).
Just set an iProp on that occurrence.
Here's a video:
Here's the code:
Dim oSS As SelectSet
oSS = ThisApplication.ActiveDocument.SelectSet
Dim occ As ComponentOccurrence = oSS.Item(1)
Dim doc As Document = occ.Definition.Document
Dim pset As PropertySet = doc.PropertySets.Item(1)
Dim titleiProp As [Property] = pset.Item(1)
titleiProp.Value = DateTime.Now.ToShortTimeString
