Inventor VBA "oDoc.Close" Still Crashes Inventor
isocam
isocam
Can anybody at Autodesk help?
I have seen a post, way back in 2015, stating that oDoc.Close crashes.
I am using this in my code and Inventor still crashes with or without the DoEvents routine even on 2020!
Can someone at Autodesk please check "oDoc.Close" to see if they get the same results?
Can you please try and fix it on the next release of Inventor?
Many thanks in advance!!!!
Darren
bradeneuropeArthur
Could you upload your code?
So that we can investigate the issue for you!
Regard,
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
