Inventor rule to change mm^2 to m^2
gregor.leban
Message 1 of 8
gregor.leban
I write a rule:
iProperties.Value("Custom", "AreaM2") = Round(iProperties.Area / 1000000,2)
That part is working.
However, in drawing I only get numbers. I would like to get a unit as well (and not writing it manually).
Perhaps is a dumb question, but I just can't figure it out...
(Inventor 2020)
Replies (7)
Message 2 of 8
Hello @gregor.leban . You can format your titleblock or just add text with format. Please see the snapshot.
Message 3 of 8
gregor.leban
Is it possible to have that write in code, like here with Mass :
Message 4 of 8
Add something at the end.
iProperties.Value("Custom", "AreaM2") = Round(iProperties.Area / 1000000,2) & " m^2"
Message 5 of 8
gregor.leban
Thank you!
I have the same code for volume:
iProperties.Value("Custom", "VolumeM3") = Round(iProperties.Volume / 1000000000,5) & " m^3"
But here something weird happens when I add  your solution at the end...
It transforms result from 0,00004 to 4E-05
Why?
Message 6 of 8
It works fine here. That "E" , I think it means something cannot be displayed like may its too long. Try with smaller part.
Message 7 of 8
gregor.leban
Yes, with bigger part it is working normally but with smaller it display that E-.
Wonder why.
Message 8 of 8
with 1mm x 10mm part, i got the same.
Maybe you can use less decimal, but you will probably get zero value. So, maybe better not use  m^3.
