iLogic iPart ChangeRow - VB.Net equivalent
NachoShaw
Advisor Advisor
NachoShaw
Hey
in iLogic, i can easily update a custom iPart by doing the following
iPart.ChangeRow(RailTP, "RAIL", TLength, TRAng, TLAng)
The function operates as ChangeRow(ComponentName, RowSpec, ParamArray)
I cant find a vb.net equivalent. The ChangeRow in the API is different-
ChangeRow(NewRow, CustomInput)
What is the ilogic equivalent to ChangeRow? I have existing custom iParts, all with a single row in the iPartFactory and i need to update the value, not change the iPart
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
you can use it in the same way
Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oiFactory As iPartFactory = oCompDef.iPartFactory
Dim oiPart As iPartMember = oCompDef.iPartMember
sStrings(0) = Length 'or increase the array pending the amount of columns to populate
'update first row with array
oiPart.ChangeRow(1, sStrings)
Nacho
