Inventor Professional 2021 Dimension text
richard_griffin
richard_griffin
Is it possible to add text to iLogic created dimensions using the new snippets in 2021?
For example, if I have a dimension created using this-
Dim linDim2 = genDims.AddLinear("Dimension 2", VIEW1.SheetPoint(-0.1, -0.1), Edge3)
and it dimensions at 400, is there a way to have it say "400 centres"?
JhoelForshav
Hi @richard_griffin
Try this 🙂
linDim2.Text.FormattedText = linDim2.Text.FormattedText & " centres"
JhoelForshav
Seems to work even better if you just do it like this.
The dimension is kept if "Hide dimension value" isn't checked in the dimension...
linDim2.Text.FormattedText = " centres"
richard_griffin
Close, but no cigar.
Error on Line 29 : 'Text' is not a member of 'Autodesk.iLogic.Interfaces.IManagedLinearGeneralDimension'.
I'm not sure if the IManaged thing is specifically for 2021 drawing iLogic or if its something that's always been around.
JhoelForshav
Hi @richard_griffin
Sorry, I dont have 2021. I thought it would return a LinearGeneralDimension.
Seems like
linDim2.NativeEntity
is of type LinearGeneralDimension though, so this should work? 🙂
linDim2.NativeEntity.Text.FormattedText = " centres"
richard_griffin
You're a legend, I had no idea what a nativeEntity was so didnt look at it. Thanks a bunch mate.
