conver string to upper case with Ilogic
Darkforce_the_ilogic_guy
Advisor Advisor
is that a way to convery an string to upper case?
so if I want to make an if statment that is true  no matter if the case of the letter is not the same ?
dim properties1= "String"
dim properties2= "STRING"
if properties1= Properties2 then
end if
JhoelForshav
Hi, use UCase:
Dim properties1= "String"
Dim properties2= "STRING"
If UCase(properties1) = UCase(properties2) Then
 MsgBox("they're the same")
