- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created materials with their own images (.jpg) that i have loaded into inventor for each specific material through the materials library and now everytime i set the material from the pull down list in my newly created .ipt the file uptains a link to the .jpg image of that material in a 3rd party drop down. Earlier verisions of Inventor this never happened. It also gets linked to the image file when you use the "Adjust " command.
Can anyone help me with these questions:
1. Has anyone else experienced this? And why is this happening?
2. When i choose the visual style of realistic i am able to see my texture of my material i created. But when i switch to shaded with edges the material becomes a solid color why is this?
3. Is their a way to quickly remove the links from every part in an assembly without having to open / go into edit , Tools > Options Panel > Links and then break each single link?
4. I dont want these to show up because when i use the copy design feature inside vault professional 2016 it brings all the image files that are linked to each part in as well and its time consuming to unselect each image file.
4. Image below shows the 3rd party links on the files i have checked out "LW-MET-0005-OPP.IPT and the main assembly 71499.iam i removed multiple links to .jgp files.
* please let me know if you have any suggestions or if you would like to me provide you with any additional information.
Design/Manufacturing Engineer
SRC Refrigeration
6620 Nineteen Mile Road l Sterling Heights l MI 48314
Toll Free: 800.521.0398
Direct Line: 248.701.1876
Fax: 586.254.0485
Email: Harris@src.us
www.SRCrefrigeration.com
www.MotorCityGrowlers.com (Check out our New Product Line & Website)
